Results 1 to 15 of 15
Thread: 6.5inch split install
    VT Commodore Executive 9C1
    Aug 2009
    Croydon Hills, Victoria
    Default 6.5inch split install
    Hi guys,
    after dealing with the crappy genuine speakers and having my drivers door speaker start popping i decided it was time to install the polk audio dB 6501's that i have, just to make it clear, i am not a novice with electronics, i have been pulling devices apart and fixing them since i can remember being able to hold a screwdriver. i really struggled with putting these speakers in, it wasnt the pulling all the panels apart and getting to the speakers, that only took about 20mins, but actually finding the relevant wires took me hours, (given i do have a 9C1 and there were 3 other looms around the drivers front area where the speakers are wired) in the end i gave up because i just couldnt find the relevant wire to cut into as well as not being able to find the original crossover (a single capacitor). so i have done the expensive option and decided to have these fitted professionally as well as getting some of the polk dB series 6x9's for my parcel shelf install as well (only going 6x9 cause i dont want a sub cause it means i cant fint my bike or all my PC gear in the back).
    I just thought i would let people know that this job isnt as easy as it sounds, i have done it in corolla's before and it didnt require much effort, but once i saw how many damn looms there were it became a different story!!
    Good luck to you all with installs.
    Matt
    Growing Old is Mandatory...Growing Up is Optional!
    My Ride http://forums.justcommodores.com.au/...utive-9c1.html
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    I don't get it, what wires couldn't you find? The speaker wires were right there once you removed the old speakers, and if your running an external amp well then your running your own wires.
    Why were you trying to locate the original crossover if you were completely replacing both the mid woofer and tweeter? The crossover which is a small capacitor that runs inline with the tweeter. It would have been far easier for you to remove the head unit and replace as much of the original speaker wire as possible providing ofcrouse that you aren't using an amplifier.
    It's a shame you had to go out and spent extra money on completing the install. It is fairly straight forward, but as with any make / model, be prepared to spend some extra time until you familiarise yourself.
    Aug 2009
    i couldnt find the actual speaker wires that run to the pretend crossover, the ones used for the sirens and lights were the same greens as what the speaker cables were, i tried, my dad tried and all my other mates are on hols, and i want them in
    Mar 2009
    Cairns White Rock
    Again i don't understand the need to find the wiring for the original crossover. The 6501 is a component set and comes with it's own crossover (unless i have searched wrongly and they are a coaxial speaker)
    Cutting the speaker wire close to the head unit cuts the crossover out and unless your extremely padantic about old loose wiring it could have just been left in place.
    Aug 2009
    im just being rather lazy, i didnt want to have to go all the way back to the head unit and re cable everything from there.....ill put it this way it just wasnt as easy as i was expecting! i really have no idea why i found it so insanely hard, your right its not that hard, but it just completely stumped me....
    VL Wagon
    Aug 2010
    Adelaide, Australia
    i don't get any of this?
    is it a poor attempt at humour?
    what on earth are you talking about lights and a siren?
    VE SV6
    Dec 2010
    Aug 2009
    Quote Originally Posted by AmmoJammo View Post
    it was an unmarked mica ambulance that my uncle had when he worked at the department of justice...i did indicate that it was a 9C1.....well done jebadayah, gald to see someone reads and understands the original post!! :P
    Mar 2009
    Cairns White Rock
    Yeah i didn't get it either, but it sort of blended in with a lot of the other badly worded posts you often see (not that yours was badly worded) which makes me assume that a good portion of JC members are on crack.
    Now i also understand
    VL Wagon
    Aug 2010
    Adelaide, Australia
    and what on earth do the lights and siren wiring have to do with the speaker wiring thats in the door? :S
    VE SV6
    Dec 2010
    I actually had to look it up as well, didn't know what 9C1 meant, ya learn something new every day
    Aug 2009
    the fact that all the wiring that was put in to operate these functions has been left, and stupidly it has been done in the same colour as the speaker cabling!! therefore meaning that i could not tell the difference between which was the speaker cable and which was the extras cables...hence why i was looking for the capacitor!
    Mar 2009
    Cairns White Rock
    But your not still using the sirens right? So even if you cut the wires and they were the wrong ones, it wouldn't have made a difference either way, all though you still went about it the hard way, and then later admitted to being lazy about it.
    You made a simple and easy thing sound hard mate, i don't really get the whole point of the thread, but i'm glad that you got your components installed, and maybe you gained something out of this that might be of use to you at a later date should you ever attempt another install.
    VL Wagon
    Aug 2010
    Adelaide, Australia
    Quote Originally Posted by schrinky View Post
    the lights and sirens were mounted in the doors?!?
  15. #15
    Aug 2009
    getting the door cable wasnt a problem, when it runs back to the loom through the rubber expander and after that is where i lost it! after that all the extra cables made it rather hard to find the one i wanted because they are all the same colour!
    Quote Originally Posted by HCVP View Post
    i will attempt another install, but maybe also next time wont leave it to the last minute!
  1. VT 6.5 inch Split speaker install
    By schrinky in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2010, 06:38 AM
  2. 6.5inch in VY fronts?
    By VY_utester in forum Car Audio
    Last Post: 03-01-2010, 08:45 PM
  3. [VIC] Autometer 5inch tacho
    By vq rat in forum Swap / Wanted to Buy / Trade
    Last Post: 24-03-2009, 07:31 PM
  4. [FS][VIC]2.5inch catback exhaust
    By Dragz in forum Parts And Other Items For Sale
    Last Post: 06-11-2007, 09:49 PM
  5. MONSTER TACHO 5inch
    By Henerz in forum Parts And Other Items For Sale
    Last Post: 30-07-2006, 07:32 PM
