Results 1 to 6 of 6
Thread: Help installing 6.5 inch speakers in VT
    Olympic VT Commodore
    Apr 2010
    Default Help installing 6.5 inch speakers in VT
    Hey guys
    So now i'm pretty decided on going with the splits, these sony ones most likely Ryda Car Audio - Sony XSGTX1620S 6" Split Speakers($99.95) and then i will be installing them myself. However as a complete noob at ALL of this im wondering if installing splits by myself is the best idea as they will be even more complicated then just coaxials of the 6inch variety.
    Being 6.5inch splits i figure you need to do a bit of chopping into the car or something to fit them? Anyways just how easy would this be for a beginner :P
    VK SL + LH Torana + VZ Crewman
    Sep 2010
    Depending on the basket size of the speaker, you may have to 'thin' the speaker pod mounting surface a little to squeeze it in. There is no other chopping involved.
    Apr 2010
    Ok sweet thanks alot, also to install the splits will i need a soldering iron or anything or can i just like twist the cables together to join them , sorry i have no idea what im talking about
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    Have a look at the crossovers, most every pair I've seen the wires screw down between plates, so just a screwdriver needed. On the speaker end does the supplied wires have spade terminals (slot on)? If so than just slide them on, if not than soldiering may be required.
    Ronald Reagan (1986)
    chooky1980's Avatar
    chooky1980 is offline Donating Member
    vh sl/e,vk berlina
    Nov 2010
    deniliquin
    should be a straight foward job mate.i put 6.5s in a mates vt and they fit it without modification to the mounting by memory
    SuperSixty6's Avatar
    SuperSixty6 is offline Alto Rullo
    Landcruiser TD
    Dec 2008
    Brisbane.
    Quote Originally Posted by Helmo645 View Post
    LOL!
    I assume you are not amping them, Or upgrading factory wiring?
    If you are not upgrading Factory wiring, You may need to solder a few things to locate the Crossover internally (I would not put this in the door).
    Cheers.
    Super6
  1. installing speakers in vn
    By haynze in forum Car Audio
    Last Post: 20-07-2009, 08:21 PM
  2. Installing 5 Inch Tacho In Vs
    By r_i_d_a_h in forum Electrical Wiring / Questions
    Last Post: 07-01-2007, 11:56 PM
  3. 6x9 inch speakers
    By russface in forum Car Audio
    Last Post: 10-09-2006, 11:12 PM
  4. installing VY 6x9 Speakers
    By cb1177 in forum Car Audio
    Last Post: 08-01-2006, 11:18 PM
  5. VN 4 inch speakers in dash
    By seabs in forum Car Audio
    Last Post: 19-08-2005, 08:51 PM
