hey guys in a bit of a pickle just figureing out my boot install, keeping it pretty basic just something a bit different, i want to mount one of my amps (see pic) between the seats ive got the position just wanting to know
1. how can i mount the board for the amps to make it stay there tec screws ect?
2.ive got another amp for sub but dont want to show it, thinking mounting it next to the big one behind back seat on the same board will the amp be okay there heat ect?
3.final question 4 guage cable okay for 2 400 watt amps? and wat fuse to use
any help ideas tips would be great guys
thanks
Benny
why not mount the amp directly on the seat? just use a big threaded wood screw (big gaps) and dont screw it too hard using the drill
if you want to hide it.. what about on the parcel shelf? get on your back and screw it to the bottom of your parcel shelf.
and if you do build an amp board.. why not build two and have one amp on each side and not screw into the center piece...
so you could still use the fold down seat to put crap?
when you buy a 4GA kit it will come with a fuse (generally 60A) just use that.
and the 4GA kit will do.
