Results 1 to 15 of 15
Thread: Sub for VE
    HSV E3 20th Anniversary Maloo
    Aug 2009
    Warragul Vic
    Default Sub for VE
    Hey peoples,
    I have a VE omega which i have slowly been upgrading the sound system in. I currently have the following installed:
    Alpine PDX-5 amp
    Hertz HSK 165 (6.5")
    Hertz HCX 690 (6x9)
    Now im Looking for a Subwoofer to go with, and i would like to know what size/brand/model sub anyone thinks would go nicely with this set up.
    JM
    old was a VY R8, 200sx daily. bring on the elsie!
    Aug 2010
    central coast
    really depends on your budget and if you want quality or just bass
    edit: also how much room you have/want to utilize
    Aug 2009
    Warragul Vic
    Sound Quality is the priority, although i do want it to have good bass. and as far as space, there is a lot back there so i am not too concerned about that aspect
    JM
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    What about budget?
    Ronald Reagan (1986)
    Aug 2010
    central coast
    ok well unfortunately i dont know much about high quality gear i only know about bang for your buck bass. which gives you a nice thud but is not of substantial quality.
    i.e. wont sound good with metal.
    sorry bout that.
    Aug 2009
    Warragul Vic
    I'm pretty flexible in budget, i.e. if its worth spending more i would, but i was hoping to spend maybe $300-$400
    JM
    Aug 2009
    Warragul Vic
    ..my biggest concern is the amount of power output my amp has as to what i could run on it
    JM
    VX Berlina
    Apr 2007
    So are you going to use the Alpine amps 5th channel to power this sub? 300WRMS? Also can you build your own enclosure or do you need a sub with one?
    VX Berlina
    Apr 2007
    Starting point, Ryda Car Audio - Boston G3 12" Car Subwoofer - Single Voice($328.85) ,
    http://www.ryda.com.au/JL-Audio-12W3...-p/12w3v32.htm
    http://www.performancecaraudio.com.a...subwoofer.html
    Image Dynamics IDQ12
    Some stuff to look up, they all seem to be able to be had for around the $400 mark.
    Aug 2009
    Warragul Vic
    yeah well thats the problem, im assuming theres nothing i can run with only 300W RMS?
    so whats the best way to go (i am a bit of a noob, i should have mentioned this earlier) should i be getting a mono block amp. can i run another amp from the previous amp?
    or is it possible to get away with underpowering the sub without that being to big of a problem.
    JM
    Aug 2009
    Warragul Vic
    and i can build the enclosure easily enough, so im not looking for one with it.
    JM
    Hektic's Avatar
    Hektic is offline Donating Member
    2006 VE Omega Impulse Blue
    Jun 2010
    I got a Kicker Sub CVR 12 i had both the black and silver one they were prety good
    http://forums.justcommodores.com.au/...lue-omega.html
    Check Out my 2006 VE Impulse blue Omega
    VX Berlina
    Apr 2007
    Quote Originally Posted by Mountnjo.2009 View Post
    Underpowering is fine, as long as the amp gains are set properly. Most SQ subs, especially in your price range, usually can't handle large amounts of power.
    You could feed 10wrms into the amp and it would still work fine. Your 300wrms is plenty for someone chasing a decent amount of SQ. Hell my first sub had 100wrms and I thought it was the bomb.
    Hopefully today or tomorrow some of the audio installers on here will see this thread and throw up some suggestions.
    EDIT: Also the enclosure is what can make or break any sub. A top-of-the-range sub in a crap enclosure = crap, a decent sub in a great enclosure = good. But we can get some designs later when you pick the sub.
    Aug 2009
    Warragul Vic
    Hmm well, ive had a look around on Alpine's website and im thinking maybe a 12" Type R sub..
    With sub boxes do they have to be square or can they be rectangular so long as they have the appropriate volume within? i'm just thinking, my gold clubs would fit in better if i could make the sub box run along the back seat
    JM
  15. #15
    VesperZ's Avatar
    VesperZ is offline 2005 Holden VZ Berlina
    VZ Berlina
    Jul 2009
    Sydney, NSW
    You can use any box with a minimum volume of about 31 litres or 1.09 cubic foot from memory.
    "Nonsense, this is the kind of coverings what we humans wear at this period of time. I'm quite sure of it."
    See my ride here
