Hey all i have a kicker 4ch zx amp and kicker sound system.
at the moment i have 2 6" splits and a 12" sub.
My idea is to run 2 more speakers in the boot install on the sides
i was just wondering how i go about wiring these up? can i just basically piggy back them into the speaker outputs or do i have to get a separate amp? ( i dnt think you can piggy back them but just wanted that clarified) thanks all
__________________________________________________ __________________________________________________ _________________________
Dman's vt exec', 19" vanquish rims, Bagged at the rear, custom boot, 2x 12" subs, tv, xbox360, custom purple interior, dash, seats, door trim, tinted
http://forums.justcommodores.com.au/...-dmans-vt.html
Future mods: lowered front, Gto Bodykit, 12mm Plenum spacer, 25mm Manifold insulator, Custom CAI,
Hook them up to the splits channel, this will run channels 1 + 2 at 2-ohm (assuming all speakers are 4-ohm) which the amp should be capable of.
So left speakers both have positives in the channel 1 positive, both left negatives in the channel 1 negative. And both right positives in channel 2 positive and both negatives in channel 2 negative.
But in all honesty I would put a switch on the boot speakers wiring, you don't want them playing while you are driving, because this will be driving those channels to their limits and will build up heat, also the muffled noise from the boot will should crap.
Ronald Reagan (1986)
ah ok thnx ill check it out
the speakers i'm wanting to put on are 4ohm, so i can just connect them with the matching polarities to where the 6" splits connect in yes? and then just run a switch between the 2 speakers?
Correct me if i'm wrong![]()
Thanks heaps and sorry to bother you
Why do you want to put a 2 6inch speaker in the boot?
Do you have a tv screen in the back or just want it to look good?
You can always use the boot light to switch the speakers on and off so they dont run all the time. Or use a mercury switch.
its just for when i open boot i dnt just get smashed with bass i actually have treble and for better looks haha but yer ok thanks all![]()
Thanks all, i finally got the boot install done and looks and sounds greatjust 2 isolating switches on the positive side to turn off speakers when not needed
I still think your a closet pimp, LOL, nah just joking. Have you thought about lining the inside of the boot lid with the same stuff?
i did, but i didnt know how i would attach it and couldnt really be bothered at this stage i mean going from the box by itself to a full boot install is a big step so im very happy with how it is at the moment but maybe one day in the future :P should see it at night though with the sound controlled neons in the port holes :P looks awsum![]()
For a bit of a cheat, the carpets are on sale on eBay, for about $40. Buy one and than attach your material on top of that. I believe the eBay kits come with all the clips and everything.
EDIT: OK my bad, clips not included, ask Holden, http://cgi.ebay.com.au/HSV-COMMODORE...item3cb454de72
ahh ok thanks for that, will have to think about that![]()
