Hello,
Just wondering if someone could point me in the right direction as to remove the head unit to install a hi-low converter in my mates VE sv6 ute.
Fascia just pulls off. Then remove glovebox and the trim panel around the steering wheel. There is the aerial connector on the glovebox side and either one or two wiring harness connectors on the drivers side that need to be removed. Then it's 4 screws from the frong holding the unit in.
Originally Posted by Reaper:
Originally Posted by Jecs:
Cheers Sabbath! Which fascia exactly am i pulling off? the one just around the head unit? or the whole piece?
Thanks Sabb!
