Hey all,
I was just wondering what you reckon the best amp is for me? I have two kicker CVR 12" subs, 800 peak, 400 rms, both are 2 Ohm. From what I have researched I would need a 2000 watt monoblock capable of running one ohm clearly... Is there any particular amp you would suggest/have tried?
I've read that some amp manuafcturers say their amps run one ohm but they can't really?
Thanks in advance,
Demetrius
Do some more research. 400wrms x 2 = 800wrms. Also the CVR are DVC subs so is each coil 2-ohm or is that 2-ohms when wired up?
Ronald Reagan (1986)
i was looking for an amp to power 2 1000watt subs and people would always say stuff like you need an amp with this and that and this many rms and stuff and chances are if your asking about amps you dont know alot and if your anything like me you need examples of what amp to get, so heres a link to the amp ive got, it powers both my subs fine and isnt to over the top expensive Frankies Auto Electrics - Fusion EN-AM60010 Mono Block Car Amplifier
anyways i would recomend it
Hey Acarmody, cheers for the reply. Yeah the impedance is 2 ohms over the entire sub, so what I researched was I would need a one ohm stable amp when I wire up the two subs. Is this wrong?
Luke23, cheers for the suggestion, fusion seems like a good choice. You're right about people saying my amp will need so much rms, ect and I am still pretty new at this. So I'm surprised that a 600 watt amp would run your two 1000 watt subs, that's awesome! If that amp will run my subs fine then i'll grab it for sure
OK so they are DVC 4-ohm subs, than you are right getting a 1-ohm capable amp.
That amp that Luke23 posted up won't even come close to fully powering your subs, its not even 1-ohm capable. The best you will get is 170wrms at 4-ohm. So feeding 170wrms into 800wrms capable subs is not really going to be even close. You will need something like this Ryda Car Audio - Fusion CA-DA12250 Mono Block Car Amplifier($489.85)
Also completely ignore words like max power, always look for RMS or continuous power, these are the true rating of the equipment.
whoops thats not the one i have, i thought the numbers from that amp were the same as the numbers on my amp because there very simular, but i wrote down the ones from mine and the actual amp i have is this Frankies Auto Electrics - Fusion EN-AM60040 4 Ch Car Amplifier does that seem more right acarmody?
EDIT-okay im confused because the one i posted the first time has the same numbers as the one i have, but if you say it couldnt power two subs then im not sure if it is, so no one listen to me haha, ill do further research tomorrow
Nah still no good, the OP needs at least 800wrms at 1-ohm or 4-ohm.
Its getting harder to find the old series of Fusion amps, the new series is overriding them, but if you can find some you should get a good price.
This one is good 1000wmrs @ 1-ohm, only $350 Frankies Auto Electrics - Fusion PP-AM200010 2000 Watt Monoblock Amplifier
So I would pay the extra $30 and get this with 1500wrms @ 1-ohm Frankies Auto Electrics - Fusion PP-AM300010 3000watt Monoblock Amp , amp will run cooler and great upgradability for the future.
he doesn't NEED that much power, anywhere from 400 - 1200watts would be ok.
Hey, thanks everyone for all the advice. Ammo you're right I probably don't need that much power but I can see me upgrading in a while so I'd rather have too much than too little. I've read some reviews and apparentally that Fusion PP-AM300010 3000watt Monoblock Amp is the best value for money. I have to agree, 1500 watt rms @ 1 ohm for only $379? I think I'll place my order tonight. Cheers =D
Hey all, just a quick wiring question, would anyone have a wiring diagram floating around off how to wire these subs up? I'm pretty keen to get them in
As stated above I have two Kicker DVC subs, each sub is 2 ohms.
I went for the Fusion PP-AM300010 3000watt Monoblock Amp (one ohm stable) as suggested.
Any help would be appreciated, cheers =D
wire them parallel, put both all the negatives and all the positives on the subs togeher then wire it to the amp
so basicly it will look like this http://ccs.exl.info/images/sp_wiring_parallel.gif
if u can wire them into a two ohm load, and run off a kicker .400 monoblock or something bit bigger like the kicker .750 all very good amps, i have the same subs and they are loud enough with the kicker .400
cheers man hope this helps
