+ Reply to Thread
Results 1 to 12 of 12
Thread: Sub Box design???
    VY 11 'Redhot' Ute
    Sep 2005
    Question Sub Box design???
    Im looking at buying a Digital Designs 9910 or a 9912, visit www.ddaudio.com for more info. i cant get my head around the port sizing i think im going insane converting from inches to cm.
    this box is suited for a 12in sub not a 10in its 2.47^ft.
    This shows all sizing in inches but my main concern is the port size. Apparently you need 16sq" per cubic foot which means i need (for a 12in sub) 40sq" but when i add up the total port size on the diagram it doesnt compare, i did y12 maths but im still confused! too confused for a sat nite.
    pictures curteous of www.ddaudio.com
    Attached Thumbnails Attached Thumbnails Sub Box design???-boxcolorcoded.jpg   Sub Box design???-boxbasicb2.gif   Sub Box design???-boxdesign.jpg   Sub Box design???-boxsingle3dview.jpg
    VY 11 'Redhot' Ute
    Sep 2005
    ohh is anyone able too look at the box design and work out the lenght of the port wall its really hurting my head? the box is 2.47^ft! Thanks
    VT Executive S2
    Jun 2005
    Morayfield - QLD
    Post
    Download versaverter. It’s good for converting just about anything and everything from metric to imperial. I dunno where you’d download it from. Just google it and see what comes up.
    2005 VZ SV6, with 19' VY Maloo Mags
    Feb 2005
    Melbourne, Vic
    the port in this sub box looks way to big
    just use a round roll like they normally are and put that in
    VY 11 'Redhot' Ute
    Sep 2005
    Yea the port is big, but the sub puts out like 1500rms or 5000peak these dd subs are made to last and for competion, im prolly not gonna compete cos i dont know a great deal about it!
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input.... Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive
    car
    Apr 2005
    Don't use a round port for this speaker, it simply wont get enought air forced out of it!
    Cameron, the only problem I saw with the box was the fact that they built it using 38mm MDF. That thickness is hella expensive and also rare as hens teeth. Convert the plans to use 25mm MDF.
    Also, in regards to the measurements... 25.6mm = 1" and there is 27Litres to a cu. ft.
    warney's Avatar
    warney is offline did you say bukakki party warney Executive
    VL skid car what else are they built to do
    Mar 2005
    and too boot ya cant find the 25mm (1in) mdf at bunnings atm ( at oxley qld) there is only 17mm but it still strong but not making the box as heavy....
    so ya have to comprise on one for the other!!!!
    VY 11 'Redhot' Ute
    Sep 2005
    im finally sane again, i had to ask DD technitians, but for that size box the port need to be 16" long, as for the mdf size on the diagram its 18mm thick, thanks for ppls help..
    VT Executive S2
    Jun 2005
    Morayfield - QLD
    Post
    Don’t get your stuff from bunnings. They are sooooo expensive. I used to work at hudsons timber & hardware (now hudsons building supplies) and we sold 2400x1200x19mm sheets of MDF for like $30 (can’t remember the exact price). At bunnings you could expect to pay that and a little bit more for something not even a quarter that size.
    Also, most hardware stores offer a free cutting service. If you buy a big sheet get them to cut it up to the sizes you need. Makes your life a little easier.
    VY 11 'Redhot' Ute
    Sep 2005
    VY SS ute M6
    Feb 2005
    if your going to make a good box u want it to be good n to last. go for the 38mm mdf. n 1" = 25.4mm
    VY 11 'Redhot' Ute
    Sep 2005
    i wouldnt need to lower my car if i used the 38mm mdf that coupled with a 15 - 20kg sub, two amps, fans, neons, mirrors, wiring plus battery mmmm im gona need beefier susp. to make my ute look normal.
+ Reply to Thread
  1. need a design
    By COO1VS in forum General
    Last Post: 05-05-2007, 04:01 PM
  2. Will My Design Work???
    By Keesh in forum Car Audio
    Last Post: 29-01-2007, 07:14 PM
  3. Rim Design??? help me out...
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2006, 12:07 AM
  4. Sub-box design (no this hasn't been posted)
    By rannex in forum Car Audio
    Last Post: 13-08-2006, 01:12 AM
  5. VE design may come from Torana?
    By Greg_Sian in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-07-2006, 04:33 PM
