Results 1 to 24 of 24
Thread: vs commodore rear speakers
    Series 1 Vs Commodore
    Feb 2011
    k town
    Default vs commodore rear speakers
    heey guys, quick question, I have two 6" kickers that I want to put in the rear of my car, will they fit, and how do i put them in, like how do i the grill's off to get to the speakers?
    Cheers,
    Michael
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    you need to take the parcel shelf out. take the rear seat out,undo all the clips in the shelf and then just pull the shelf out
    Feb 2011
    k town
    VR Berlina
    Jun 2010
    VIC
    u can try and pry the grills off and poke the speakers through the hole in the shelf but its quite difficult. your better off just taking the parcel shelf off and making life easy for yourself. i had to my rear seats out to take my parcel shelf off
    Feb 2011
    k town
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    For the fronts you need to remove the door trim, search for a how to on here. It's not that hard to do though once you work out how, and probably worth a go yourself. Just be sure the new speakers will fit first, which the should if they are just 6 inches and not a strange design. You can get a small tool to make taking the trim, especially window winder and lock off easier.
    Feb 2011
    k town
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Nic92's Avatar
    Nic92 is online now Rough As
    2002 VYS S1
    Mar 2011
    WA
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    not in a vr/vs,theres no speakers in the back doors at all,thats not to say it cant be done,just that by the time you stuff around doing it,it would be easier to remove the parcel shelf
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Yeah there's no speakers in the doors. The 6" ones you have should fit perfectly. I have 6.5" in the back of mine and from memory I had to make wooden spacer blocks (screw block to parcel shelf, then speaker into block, etc) so they sit up a tiny bit. but still underneath the parcel shelf.
    Just whatever you do, DON'T CUT THE PARCEL SHELF IN ANY WAY. Voids your rego, insurance, etc etc.
    have a search around next time, try this thread for info on removing the door trims / installing front speakers.
    Removing Front Door Trim on VN - VS
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    ohh ok, i didnt no they didnt have speakers in the rear doors, i thought all commo's did but anywho, so the vs commo's only came with 2 speakers?? i thought maybe if they came with 4 all u have to do is replace them
    VR Berlina
    Jun 2010
    VIC
    Quote Originally Posted by Nic92 View Post
    they have 4 speakers. some even have six. theres 2 tweeters in the dash, 2 in the front door and 2 on the rear parcel shelf
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    ohh ok, then all he has to do is unscrew and take the old ones out and screw the new ones in?
  15. #15
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
  16. #16
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    ic :P its a pitty i cant put speakers on my parcel shelf i would like to put 6x9's on my back shelf on my VY but as u can see i think they would break, this is mine YouTube - RE Audio SX 18" Subwoofer in a SEDAN Holden Commodore VY S watch at 2:34
  17. #17
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    6x9's dont go well with subs anyway,they cancel out some of the bass from what ive read,better off sticking with 6 inchs all round
  18. #18
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by Adds_05 View Post
    yep spot on, if you're running a sub doen't use 6x9s
  19. #19
    Zarconia's Avatar
    Zarconia is online now Outrageous Fondler
    96 VS Executive Series 2
    Aug 2010
    Rockhampton
    Ive got 6x9's in my vs and use to have 6" in my old vr, the bass is ALOT louder than it was in the vr but that may also be due to them running off separate amps. All depends on what your running i would think
  20. #20
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  21. #21
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    If you're not running a sub, definitely run 6x9s. If you're running a sub, don't run 6x9s.
  22. #22
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    hmm ok then i need louder door speakers to keep up with the sub.. and with tweeters how do u install them lol.
  23. #23
    Zarconia's Avatar
    Aug 2010
    Rockhampton
    Either buy aftermarket tweeters or rip the tweeters out of your speakers the place them where you want them and re-route the wire
  24. #24
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Theres 2 screws holding in each demister panel, you'll need a short stubby philips head screw driver to get at them. Magnetic one too, careful not to let the screw fall in the vents like I did lol.
  1. Rear speakers VS Commodore
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2009, 09:23 AM
  2. VR Commodore wagon rear speakers.
    By mil016 in forum Car Audio
    Last Post: 25-02-2009, 12:27 PM
  3. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  4. Rear Speakers In Vn
    By haynze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2006, 11:13 PM
  5. VS Commodore changing rear speakers
    By Coppermine in forum Car Audio
    Last Post: 30-03-2005, 08:01 PM
