Results 1 to 10 of 10
Thread: Sub turning off and on ?
    2004 VYII S, 2005 VZ SV6
    Jan 2009
    Default Sub turning off and on ?
    Ok, so ive rewired most the car, replaced 8 gauge with 4 gauge and added all the extra rcas through the car for the 4 channel amp when it goes in, but..... Whenever i turn the car left or right the sub will cut out or cut back in, also happens when i reverse sometimes, its really strange and bloody annoying, has anyone else had a problem like this before, ive tightened just about everything i can think of, redid the wiring in the sub box to a thicker wire, checked fuses, almost out of ideas !!!!??
    Also is it ok to run 4 gauge and then link to a distributor block and run 2 x 8 gauge off it, running for maybe 30cms as 8 gauge, or would it be better to to run as 4 gauge all the way - this would be to power 2 amps btw ?
    Thanks guys
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Have you checked the RCA connections behind the H/U. Often when you push the H/U back in it can push the wires around, and sometimes come out.
    Ronald Reagan (1986)
    Jan 2009
    Yeh, i had this problem with the previous installation, mind you all the wires were the cheapest nastied you could ever buy, but yeh, now its a different set of rcas, and i made sure the head unit wasnt forced in... Dunno if this helps - but i ran 3 sets of rcas down the left of the car and the 4 gauge down the right side.
    Jan 2009
    Ugh after hours of trial and error, ive come to the conclusion that the amp has taken an impact of some sort when autobarn installed it, its missing 3 screws and seems very loose in the part where you do the earth, power section of the amp, slightest touch to that area when its going turns it off and on, hoping theres some kind of way to stiffen the connection back up
    VX Berlina
    Apr 2007
    Is it too late to go down to Autobarn and smack some heads in, oh and get them to fix it too?
    Jan 2009
    Probably too late, and im not sure on their policy of BYO gear for them to install... On the plus side i turned it up most the way home and it didnt crap out over bumps or corners, bloody strange
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    RE: the one 4ga to 2 8ga. I'm doing that now no trouble, actually ive got a third going now (I have a 1 4ga-4 8ga dizzy block)
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    I'd still be hitting autobahn up for some kind of fix or reimbursement despite your byo gear. Just because you didn't pay for the stock doesn't mean you didn't pay them to install it.
    And when you pay the for a service, they have an obligation to provide the service you pay for.
    At the very least, start a complaint, you've got nothing to loose..
    Nic92's Avatar
    Nic92 is online now Rough As
    2002 VYS S1
    Mar 2011
    WA
    Jan 2009
    Too lazy to go back and whinge to them about breaking the amp, i know theyll deny it and waste my time, on the plus side i bought a 900w monoblock and a 900w four channel amp instead... It was definately not th wiring - i had hooked up a four channel amp and it has run fine the whole time and its off the same wiring as the monoblock was (different rcas of course)... What a hassle that was, thanks for all the input guys it really did help during the trial and error of it all. Oh VKCOMMO i decided to go with 4ga - 4ga through a t block and earthed both amps at different points. So much to learn about all this
  1. Accessories turning on by itself after turning car off
    By Danny40 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2011, 11:04 AM
  2. HID not turning on...
    By phatvtcom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-11-2009, 11:17 AM
  3. turning off?
    By msina1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2009, 08:51 PM
  4. ESP turning off
    By ascottaudio in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-06-2009, 10:23 AM
  5. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
