Results 1 to 12 of 12
Thread: how to bypass Hand Brake wire to make dvd work?
    VY II SV8
    Oct 2010
    Near Gawler
    Default how to bypass Hand Brake wire to make dvd work?
    Im trying to install Pioneer head unit, mvh 8250, and i want to bypass the hand brake to make the Multimedia section to work. The Unit requires a wire to be installed in to the power feed in to the Hand Brake to the DVD player to work. I dont want to use the Hand Brake, i want to dvd player to work on demand. The car its getting installed into is a 97 VT berlina V8. Any help would be great. Cheers
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    You could move the black button (sensor) at the base of the handbrake off to the side. That should trick it into thinking that the handbrake is always up and should allow the DVD player to function.
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    vt s pack
    Oct 2010
    brisbane
    lol earth it on anything.
    works for my apline one,
    can put a hidden switch if ur scared by cops
    boomnvn's Avatar
    boomnvn is offline SOLDER, NO CRIMP.
    VT Exec S1 V6
    Oct 2006
    Croydon
    don't disconnect the sensor like rusty said, this will make the handbrake light stay on the dash and when you're moving it'll be beeping away.
    best way is to earth the handbrake wire with the earth wire to the head unit, but just be cautious that if you get pulled over, best to fold the screen away, or turn it off all together.
    cheers,
    spudley.
    CAR: VT Commodore Sedan audio car - SOURCE: 7" double DIN DVD/GPS - AMP: Pioneer monoblock / Pioneer 4 ch. - SUB: Kenwood DB+ 12" in 22lt slot ported box - REARS: Kicker RS60.2 splits - FRONTS: Kenwood KFC-S702P splits - MISC: Custom fiberglass iPhone4 dock moulded in center console, White / red LED cluster and dash lighting, SAAS Vortex drivers seat
    Rob_VT's Avatar
    Rob_VT is offline Smacked Up
    VT SII
    Jan 2010
    Warilla, NSW
    Default Solution = relay
    hey mate i just done this on my pioneer avh p4350dvd
    you need to get a 12v single pole double throw relay.
    you cant just ground it with pioneers, thy need a delayed signal to ground.
    go to super cheap, get a relay dont use the guide on the back of the box, super cheap got it wrong.
    on top of the relay itself (i used a narva one) it shows the ciruit. split your remote signal wire that goes to your amp, and run this to the power pin (86) run a ground from the other side of the coil (85) and another ground from the normally open contact (check the relay circuit, will be 87 or 87a, the picture shows them both open but the switch will be connected to one) and finally run the green hand brake wire to the switch (pin 30)
    Attached Thumbnails Attached Thumbnails how to bypass Hand Brake wire to make dvd work?-relay.jpg
    Rob_VT's Avatar
    VT SII
    Jan 2010
    Warilla, NSW
    Default Edited picture
    edited the picture (very quickly and badly, but u get the point)
    blue is remote wire 86
    blacks are grounds 85 and 87
    green is handbrake wire 30
    87a is normally open contact.
    hope that makes it a little more understandable.
    MEESEN's Avatar
    MEESEN is offline V8 6 Speed coming :D
    '03 VY
    Jun 2010
    commodore
    Aug 2009
    australia
    just earth it straight to the body ,i did with my old pioneer dvd headunit .
    '94 Holden Calais VR V8
    Jan 2009
    Western Suburbs, Melb
    Hey Bud, U just earth it to the body and it works fine. We used to do this at work for customers who didnt want the hand brake setting connected.
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    Just ground it out and it will work..
    Zapp
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
    Rob_VT's Avatar
    VT SII
    Jan 2010
    Warilla, NSW
    Arrow
    On newer Pioneer dvd head units, you cant just ground the signal.
    I have a Pioneer AVH P4350 and i tried grounding the signal and it does not work,
    the older ones may work, but the new ones need a delayed signal to ground so even if you wire it correctly to the hand brake sensor, you need to put hand brake off and back on.
    choices are a relay as i said before, a single pole single throw switch, or a normally closed momentary switch.
    relay is easiest and neatest as you can hide it.
    and if your "worried about cops" as some people have been saying to support switch idea, u can press mode and mute within 1-2 second which cuts screen and volume on newer pioneers.
  1. any way to make a th700 work in a vs??? please help
    By Dusty_vs in forum V6 Development And Modification
    Last Post: 13-03-2011, 09:28 AM
  2. Can work make you take out peircings
    By Timmos in forum The Pub
    Last Post: 01-12-2010, 02:08 PM
  3. Adjusting Hand Brake shoes ( disc brake )
    By Fusion in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-06-2010, 01:35 PM
  4. Parking brake bypass
    By GMHCalais in forum Car Audio
    Last Post: 30-12-2009, 10:03 PM
  5. Make a wire feeder
    By jonesboy1 in forum Electrical Wiring / Questions
    Last Post: 02-10-2005, 10:55 PM
