Should just do it to the bolt that already has an earth strap/wire on it?
Thats how I did mine...
Didn't know this mod was called "The Big Three" I just did it to try and cut down some alternator/ignition - interference/whine.
Do you think you'd need 0gauge wire from the back of the alternator, the thing only puts out like 100amps?
them 2 connections were positive..
you could use 2 gauge but 0 gauge is better
youd be better off doing the full big 3 upgrade![]()
Go to an auto electrician, have them put 0 ring hex crimped terminals on all cables, bolt the cables together and heat shrink like a mother ####er, will be much neater and also work a lot better. That is a bit unsafe imo. Otherwise good job mate.
you mean nornal ring terminals? i got plenty of them
Time for you to work on removing those vibrations.. Makes your car sound cheap
Originally Posted by garth
what song is at 2:30? :P
massive vibrations tho :P
Lil Wayne - My house - Tha Carter 2
Just done this mod today, havnt driven at night yet to see how the light dimming is, but when I used to do the old Mode + Up trick my volts used to be bouncing up and down in the 13s, now its sitting steady on 14.1![]()
It's called a distribution block, one like the following would be perfect:
0/1 gauge input, two 4 gauge outputs
Another solution would be a "T" or "Y" connector with 0/1 gauge in and two 4 gauge out.
Just sayin' cause that's pretty dodgy.
Sorry for the thread dig, But does anyone know the measurements of the cables that need to be upgraded so i can cut them up and get them all crimped before i pull the old ones off the car.
I doubt anyone would off the top of their head. Just grab a roll of string, take it out to your car and cut up some pieces.
i never measured them, i had a 50ft roll so i connected them and cut how much i needed
i guess i better put new pictures because the older ones are all stuffed
Cheers for the string idea.. And the new pics
Too easy. Just bare in mind Nic is a strong believer in the old do it "quickly and dodgy" job. All exposed wires should be heat shrinked or electrical taped, try to use HEX crimped lugs for the best connection.
yeah i do tape them, i just took the photo's to show it is conencted, you get the point anyway![]()
i brought bolt battery terminals so il post up pictures of how it was ment to look when i did the big three, i thought the audio ones would work out but i didnt realize how many wires there were so i had to improvise and it worked for a while then i had problems and changed it and did that ^ for temporary (the other pictures in attachments)
this is just for other people who are doing the big three upgrade and unsure on what to do.
