Will a Pioneer GM-D8500 (600rms) mono block amp run a Kicker 10DC122 2 x 12" Subs (2 x 300rms)?
yeahh why wouldnt it, just be careful with the volume and set the gains right coz them subs are rated 150rms each, the most i have given one is 200rms and they hit pretty hard, so yeah the answer to ur question is yes, just know what your doing
The subs are already factory boxed. they run at 2 ohm. I also meant 300 rms each lol (300 + 300) will it be enough to power it?
Sweet as mate thanks for the advise. Do you reckon its worth installing a second battery?
umm, get a cap, i installed a second bat/cap wen i got 1200rms, but with 500rms i just used a 2 fared cap and my amp was 58% efficency class a/b and that pioneer amp is class d so you wouldnt need a second bat, but at least get a cap, it really does help! plus you probably wouldnt be using the amp's full power on them subs
