Results 1 to 6 of 6
Thread: Help please. Is this amp sufficient enough to run all four speakers
    VE SV6 Sportswagon
    Apr 2011
    Default Help please. Is this amp sufficient enough to run all four speakers
    Hi Guys,
    I purchased a VE SV6 sportswagon 4 months ago and I want to start upgrading the sound system. First off, I would like to start by running an amp. I have an old 4ch amp, is it sufficient enough to run all four speakers with it.
    Any information would be great.
    Thanks.
    Attached Thumbnails Attached Thumbnails Help please. Is this amp  sufficient enough to run all four speakers-poweracoustik.jpg   Help please. Is this amp  sufficient enough to run all four speakers-poweracoustik1.jpg   Help please. Is this amp  sufficient enough to run all four speakers-poweracoustik2.jpg
    VZ Ute
    Mar 2011
    hey mate,
    would depend on how loud you want your system and what the power handling of the speakers is. Any amp, generally speaking, with 4 channels will run 4 speakers it just may not be as loud and clear as you would like it to be. Comes down to how much power your amp puts out and the power rating of your speakers. (RMS rating not max power rating)
    VE SV6 Sportswagon
    Apr 2011
    thanks for replying. The amp itself is 400 watts (max power) . I want to install 60rms speakers in the front and in the back but I would also like to know if this amp can be used with out RCA's.
    VZ Ute
    Mar 2011
    If you mean your head unit does not have RCA outputs then it is possible to put RCA plugs on the end of standard speaker wire outputs. But in saying that i have never attempted to do so myself so i cant vouch for the quality of it. But if that is the case it would probably just be easier to buy a head unit with RCA outputs. And yeah that should run your speakers fine.
    VZ Ute
    Mar 2011
    oh i didnt notice your amp actually had a hi input option, you should be able to run speaker wire from your head unit to the amp in that way. sorry didnt even notice that on your amp.
    that actually made no sense as my previous post didnt come up. yeah thatll run your speakers. and if you mean that your headunit doesnt have RCA outputs then you can use speaker speaker channels to the hi input on your amp, never done this before myself though, always just used the RCA inputs. hope this helps
    VZ Exec Wagon
    Apr 2009
    Manly, NSW
    Its 400watts max. But It's should only be about 180-200watts nominal. So 4 x 50watts. Should be fine for a sound upgrade
  1. [SA] Pioneer - TSA1702C Split System Speakers & Sony XS-F1020 Speakers
    By Tw1n Tur6o in forum Parts And Other Items For Sale
    Last Post: 03-01-2011, 04:50 PM
  2. Replies: 3
    Last Post: 12-10-2010, 04:30 PM
  3. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  4. Replies: 18
    Last Post: 06-01-2008, 07:09 PM
  5. Replies: 9
    Last Post: 29-06-2005, 05:49 AM
