What will sound better with or without a cone, i listen to hiphop/rap dubstep more bassy stuff,
cheers,
"You need money to make money" unfortunenately this isn't true if your spending money on cars.
I find that kind of music sounds best if you use one of these cones.
wtf mate?
please explain...
haha thats what i thought when he said cone ^
haha
Gold.
Def with
The cone is part of a subwoofer, and a sub box isn't much good without a subwoofer, so that's a pretty clear YES.
Maybe you mean port? As in a ported or sealed enclosure?
i thought he ment port to when he said cone
If you mean ported or sealed box, depends on the sub. Ported is usually the way to go with high-wattage
yeh so, as hillarious as the cone jokes were, i meant the hole in the sub-box with a peice of polly pipe filling it.
err, you cant just cut a hole in a box and use it as a port, unless you tune it
it'll depend on ur specs on the sub, amp and the box built. r u building a box or gettin a pre fab 1?
As previously said, you can't just chop a hole in your box and call it a port. A port has to be a tuned length, tuned diameter, exactly the right size or it will just screw things. Also, depends on your sub, some models don't suit a ported box that well.
