Results 1 to 6 of 6
Thread: ve upgrade
    VY S soon to be SS
    Feb 2009
    NSW
    Default ve upgrade
    just a few quick questions about upgrading the ve.
    what are the decent brands of line out converters ?
    if i want to run 2 amps will i need 2 converters ?
    can you just a sub without a converter ?
    if i want to replace the door speakers will the new ones clip ?
    recomended types of splits in the 200-400 $ range?
    cheers
    live fast---drive faster
    Black ssv redline ute
    Oct 2010
    brisbane
    doing this upgrade atm with a s2 ute
    i just brought my converter from jay car same one is sold in repco aswell price $16.95
    after looking round on net had some troubles finding any others. The converts only do 2 channels so if you do front speakers you need 1 if you do front and back you'll need 2 and if doing a sub aswell i'm just going to split the rear RCA's to do the sub aswell as the head unit doesnt have a separate line for the sub.
    As for speakers its more a personal taste i like Alpine or pioneer as these are quite crisp and clear sound i tend to stay away from sony as they seem to give a bit to much base making them not as clear.
    I'm putting in pioneer 6.5 inch in door with splits in dash from what i hear the door should just sit in to the speaker hole with some slight trimming needed but i havent got that far yet will post up when completed
    VY S soon to be SS
    Feb 2009
    NSW
    thanks for the reply mate, ive got a ute so theres no need for rear speakers. im thinking ill just get some nice splits and feed them as much power as i can.
    what is the converter called ?
    does anyone know if it would be better to use a converter or to find an amp that will take speaker wire ?
    also as for speakers ive had a listen to a couple and liked the rockford fosgate T1652-s and the alpine type Rs . any one have advice on these two speakers and poibly a 2 chanel amp to rum them to full potential without spending million's
    and if i want to later hook up a sub will i have to split the front RCAs or is there another way ?
    cheers
    09' VE SSV Special Edition
    Oct 2010
    Wollongong
    I run the following in my VE ssv ute;
    High Pass Amp
    2 x 6.5" focal splits
    1 x 13" focal sub
    Everything runs off the amp with no line out converter needed. Sounds incrediable - I got mine installed by a professional shop, I would suggest you do the same.
    VE II SV6 thunder ute
    Jun 2011
    gymea
    is that sub a slim line or just normal? I have been looking into the slim subs just to fit nicely in the cabin. But i am seriously considering doing a total focal set up.
    HUX 90's Avatar
    HUX 90 is offline POSION VE SS UTE
    09 VE SS UTE
    Mar 2011
    I'm running Alpine type R 6.5" splits and a Polk 4" centre speaker. I'm looking into getting this alpine amp MRP-F600 to run the splits and a sub.
LinkBacks (?)
  1. 25-05-2011, 07:54 PM
  1. Brake upgrade kit - missing bolts!?!? (RDA VE upgrade for VS SS)
    By gsxr6000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2011, 10:35 AM
  2. What else to upgrade?
    By daz08 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 01:47 PM
  3. some 94 VR upgrade help
    By Adriianz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2009, 12:56 AM
