Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Like Tree1Likes
Thread: sub draining battery
    1999 vt exec series 2
    Oct 2009
    Default sub draining battery
    i need help i love my sub and i wanna keep it.
    im thinking of installing a second battery or something to stop my killing batterys and frying alternators.
    any help would be coota
    Nic92's Avatar
    Nic92 is online now Rough As
    2002 VYS S1
    Mar 2011
    WA
    Oct 2009
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    if you're killing batteries and frying alternators, a capacitor isnt going to fix it.
    i think a little more detail as to whats happening will be needed before anyone can help you.
    one_and_only2004's Avatar
    one_and_only2004 is online now Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Do your lights dim considerably on the low notes?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    Well mine getting to the point I almost need a new battery, you could get a decent Battery and get a decent Capacitor (1-2-5-10Farad, depends how big it is)..
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I love how you kids talk about capacitors.
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    WM Statesman
    Sep 2009
    South Gippsland
    Upgrade all your factory earths and the charge wire to 0 gauge first.
    Its often called the "Big three" google it.
    Mar 2008
    Ditch the stupid capacitor ideas - run bigger cabling for your +ves and earths.
    91 vn s
    Jun 2009
    Adelaide, SA
    as above ^ capacitors dont do much besides add weight to your car. Get a good battery, good earths, good cabling.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by somefool View Post
    b4 when i was running a 500rms, i had a cap installed and the bat power was fine then wen i took the cap out, it would cut out and all and wasnt enough power, so from my experience they really do help
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Quote Originally Posted by Nic92 View Post
    i think he's exaggerating a little bit on frying alts and killing bats, any sub/amp is gonna drain the battery..
    since wen? it depends on the set up and how much amps its pulling. half the time guys dont bother with upgrading the main grounding points and/or checking the alternator is up 2 scratch.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Quote Originally Posted by HoZy View Post
    I'm with you mate. We need more details, i run 2kwrms with no dimming of lights, slight voltage drop if i'm a wanker and turn the boost up.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
  15. #15
    Dec 2008
    Chances are it would have all been fine on 500wrms if you upgraded the factory earths and alternator charge wire 'big 3 upgrade'. 500wrms isn't much at all mate.
  16. #16
    Oct 2009
    S.E VIC
    Quote Originally Posted by sweefu View Post
    That's lucky xD. I'm running 800WRMS into 2 ohm and my lights dim like hell. But I'm going to assume the battery is on the way out. I am running a 4 guage kit not 0 guage, but with only have a moderate bit of power in mine it should be enough.
    EDIT: And no, I'm not using a capacitor. Don't plan on it either unless I just want to stop the dimming, not for more power.
  17. #17
    Dec 2008
    If you want to stop your lights dimming, then upgrade the engine bay wiring. Batt- to chassis, Batt- to engine, Batt+ to alternator charge. go to an auto elec have them make up some decent cables with hydraulic hex crimped ends, i imagine for 4awg or even 0awg it can't cost $50, your problem would be fixed. Ensure your earths are rubbed back to absolute bare metal. Unless your battery really is f*cked.
  18. #18
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    ohh i forgot to mention. it was a class A/B amp and it was
    Efficiency (average)
    67% @ 4-Ohm
    58% @ 2-Ohm
    i was running at 2ohm
  19. #19
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It still shouldn't cut out unless your power supply wasn't up to the task and I know for sure that a healthy VY electrical system could run that amp with no issue. Your capacitor was a band-aid to cover up another issue.
  20. #20
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  21. #21
    Oct 2009
    S.E VIC
    Gotta buy the bigger terminals too :P. But yeah, fair enough.
  22. #22
    Dec 2008
    Nah, all fits on stock terminals, although a bit messy looking and crowded, it still all fits safely and fine.
  23. #23
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  24. #24
    Dec 2008
    Doesn't mean its essential to replace them, they are still functional.
  25. #25
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    If you feel like a new battery, a D34 YellowTop (750CCA's), which is the one that 99% of high end car audio people use and trust can be purchased hassle free at www.optimadirect.com.au
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
  1. battery draining!!!!! NEED HELP!!!
    By my99ss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2010, 04:15 PM
  2. vr keeps draining battery
    By firsttimevrowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2010, 12:53 AM
  3. draining battery
    By whitey08 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2008, 01:37 PM
  4. Battery draining!!!
    By Pure Evil in forum Electrical Wiring / Questions
    Last Post: 28-09-2007, 01:02 PM
  5. battery draining.........
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2005, 03:15 PM
