Results 1 to 2 of 2
Thread: VE Amp options - 1 or 2 & how many channels??
    Calais57's Avatar
    Calais57 is offline Donating Member
    VE Calais V 6.0
    Jan 2009
    Blue Mountains, NSW
    Default VE Amp options - 1 or 2 & how many channels??
    I have read everything I can find about upgrading the VE sound systems. Plenty of great info but I can't find answers to my amp questions.
    My system upgrade so far (fronts installed and the rest is yet to go in):
    - Front: Hertz ESK 165 components (splits) RMS-100W (4 Ohm).
    - Centre speaker: removed
    (Very good improvement is noticeable up to this point but not fantastic)
    - Rear Doors: Hertz ECX Coax RMS-70W (4 Ohm)
    - Subs: 2 of the Kicker 8" (10CVT82) RMS 200W (2 Ohm). I am told that to run subs in-shelf "Free to Air" that they should only be powered to about half to 3/4 of there RMS power rating.
    - Dynamat Extreme for rear shelf and doors
    Criteria for choices:
    - low/mid level upgrade to keep costs down (but still way better than stock)
    - boot space is critical (often full and need to use back seat as well)
    - do LOTS of country kms & need spare so can't use that space for a sub.
    - unlike a lot of you young blokes (or young at heart/ears), I rarely would have the sound system above about 20 in volume. Usually below about 16.
    - I want the rich LOW VOLUME sound with decent base that I am told is available only via amplified speakers and subs.
    Questions:
    - Is a small 1 or 2 channel amp for the subs enough
    - I don't think it will be, so should I go with a 4 channel for speakers AND a separate 2 channel for subs
    - OR is it better to go for a 5 channel straight up?
    - Would the 5th channel on a 5 channel drive both small 2 Ohm subs?
    - ANY other comments/recommendations very welcome - even to tell me I have made wrong choices if necessary!!!
    Thanks!!
    Calais57's Avatar
    VE Calais V 6.0
    Jan 2009
    Blue Mountains, NSW
    OK - have had suggestions today that a single 5 channel would be better/ easier etc but that they can be large in size.
    Any suggestions about good 5 channel amps to drive
    Thanks
  1. HELP ? about amps and channels.
    By kizza50 in forum Car Audio
    Last Post: 20-06-2010, 04:23 PM
  2. Two amp channels stopped working
    By sweefu in forum Car Audio
    Last Post: 15-09-2009, 04:53 PM
  3. Rear channels activated, how to? ute
    By Ryan.mate in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-07-2009, 02:46 PM
  4. window gutters / bailey channels
    By QNLOOK in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2006, 10:06 PM
  5. unable to get 4 channels working
    By vx-s_Man in forum Car Audio
    Last Post: 05-03-2006, 07:59 PM
