Results 1 to 9 of 9
Thread: Amp not working
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Default Amp not working
    Hi guys..
    I have just bought a cadence 400w monoblock amp to power 2x 12" clarion subwoofers..
    earth is ok
    power is ok
    remote is ok
    sub speaker cables are ok
    rca's are ok
    my problem is, if I have the gains set to 0 the amp powers on. The moment I either turn the gain up a bit, or turn the stereo up, I get maybe 1 beat from the woofers, then the amp shuts down, it doesnt go into protect mode.
    I *had* the earth using a bolt for the middle seat, however i have also tried a bolt in where the top of the middle seat clips into, also tried the boot catch bolt. im unsure if the earth is the problem.
    I've researched the ohmages and they check out fine. I also made sure the back of the woofer, to the box, to the amp positives and negatives are fine.
    Any ideas?
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    fuse...on amp
    wires come off speaker inside box (seen it on my one)
    to check ground use multimeter on ohms setting at the amp end (disconnect earth cable from amp)
    and go from there to another bolt nearby it should read like 0 ohms-ish
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    Just checked the fuses on the amp, they are fine..
    I shall check the ohms setting on the ground..
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Hey Trent,
    Are your subs 4ohm or 2ohm ?
    Is the amp 2ohm or 4ohm ?
    By any chance would this be a Cadence XA400.1
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    for the purposes of this thread, and only for this thread....
    amp is 2 ohm,
    subs are 4 ohm ea svc.
    and yes its thde xa 400.1.
    gonna take a wild guess though, and guess people have spoken to you though.
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by tr3nt View Post
    amp is 2 ohm,
    Spoken to me? I was just asking so I can take a look at an online manual. An they do 2 different types in the 400w range. So thought I'd ask.
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    has this amp ever worked?
    Sub blown?
    looks like a shortout but not going in protect makes it look faulty
    VT Executive V6
    Dec 2006
    QLD
    have a close look at the large gold fuse in the 12+ v line, something similar happened to me when the cap on one end came loose, it rooted an amp too. Worth checking out anyway
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    My system did the exact same thing as yours and it was the earth. Just give it a lil more of a tighten haha :P Just for checks.
    Edit: and make sure it's direct metal on metal, like a lil bit of paint or something rub it back to metal on the point.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
  1. Replies: 2
    Last Post: 07-10-2009, 02:40 PM
  2. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  3. Air con not working VN
    By DanVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2008, 08:25 PM
  4. Fan not working
    By croz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2006, 09:23 PM
  5. No ECU working at all !!
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2005, 05:50 PM
