Hello all, I recently purchased a Powervox amp ( see link ) New PowerVox 2800 Watt 4 Channel Car Amplifier Black | eBay that claims it is bridgeable. The problem is, in its instructions it doesn't explain how to bridge it, so i was wondering is there a rule that if the amp is bridgeable, and unless it says otherwise then the positive of your speaker connects to positive of channel one positive and then negative of speaker connects to negative of channel 2?
How do i know if i should
A) connect positive of channel 1 to one speaker wire and negative of channel 2 to other speaker wire
or
B) connect positive of channel 1 to one speaker wire and positive of channel 2 to other speaker wire
Can anyone help me?
__________________________________________________ __________________________________________________ _________________________
Dman's vt exec', 19" vanquish rims, Bagged at the rear, custom boot, 2x 12" subs, tv, xbox360, custom purple interior, dash, seats, door trim, tinted
http://forums.justcommodores.com.au/...-dmans-vt.html
Future mods: lowered front, Gto Bodykit, 12mm Plenum spacer, 25mm Manifold insulator, Custom CAI,
positive to negative of each channel seems to be the norm.
you will find that the amp will have a......................+.....- .......................+......-
and under it will say bridge, ill try draw it................^---------bridge---------------^
so it will have it written LOL sorry i dont know if u can understand this or not,
and i had a old verson of this amp, still do just not running it anymore, and if u work out all the settings correctly they put out some awesome power, it worked amazingly for mei loved it
only reason i swapped it was cos the old versons are long and i wanted to mount the amp to the back of the sub :P
use the positive of channel 1 and the negative of channel 2. use the positve of channel 3 and the negative of channel 4 for the other speaker or subwoofer
If all else fails and you can't work it out, if your running dvc subs connect each voice coil to a separate channel![]()
cheers guys thanks for all the comments and also one quick question if i link the positive of channel one and negative of channel 2 with the speaker, do i connect the remaining negative and positive with a short wire???
ah ok thanks, so i just connect channel 1 positive to positive speaker wire and channel 2 negative to negative wire and thats it?
Subwoofer Wiring Diagrams this sites awesome, takes a bit to figure out but once you do its really helpful.
ahh ok thanks heaps, and sorry :/ i looked on google but i wanted to make sure that it was negative to positive for powervox amps coz some amps are positive to positive but thanks heaps
i thought so but i read on 4 different websites so then i started to believe it but yer, thanks heaps and sorry for my lack of knowledge :S
very true, i just thought id be on the safe side haha when sites were saying different things i got confused :S but cnt wait to test it out tomorrow :P
