Results 1 to 8 of 8
Thread: VY Amp power
    VY SS
    May 2011
    Auckland
    Default VY Amp power
    Hi all,
    I'm wondering whats the easiest way to get two 4 gauge runs through the fire wall on my VY SS? Don't particularly want to cutup the main power grommet if i can avoid it (plus it seems to be a void in between the two grommets? Is there a way to get back in from inside the guard?
    I'm planning to run a sub on high levels off the rear speaker channels until i get a processor (still deciding between alpine h800 and audison bitone). Which i will most likely come to ozzie to get.
    Taylor
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Nic92's Avatar
    Nic92 is online now Rough As
    2002 VYS S1
    Mar 2011
    WA
    VY SS
    May 2011
    Auckland
    I've already got two 4 gauges because i had one running in my last car then when I put the second amp in just grabbed another one and ran it down next to the other one.
    Initially i want to run one 4 gauge, since the factory system lacks bottom end, to get the sub going. Then I probably will just grab some 0 gauge and change it over.
    There dont appear to be any spare factory grommets on the firewall that i can see, i'd rather go through the factory power grommet then drill a hole.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    VY SS
    May 2011
    Auckland
    That was the grommet I was looking at. Quite tight to get at. Did you just slit it with a knife and push through? Was it hard to get from inside? I removed the aircon bit on the end and you can kinda see it but cant really get my hand in there. Cheers
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by m1lky View Post
    umm, yeah easy just cut it with a sharp knife or something and slide teh wire thru, ohh
    also it is much easier with a coat hanger to tape the wire to it so it can go easy thru the hole, mine was done with 8 gauge then 4 gauge then i did 0 so.. make the hole then poke it with a coat hanger
    VY SS
    May 2011
    Auckland
    Sweet. I'll do that tomorrow. Cheers for your help mate
  1. [NSW] FS: New NOS VN-VS Power Mirror controls In Holden Packaging, Used VN-VS Power Mirrors
    By VKCOMMO in forum Parts And Other Items For Sale
    Last Post: 16-03-2011, 05:23 PM
  2. Power wire from central power windows??
    By zachy in forum Electrical Wiring / Questions
    Last Post: 07-12-2010, 12:30 AM
  3. Clunk while applying power, changing power etc.
    By Skidney in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2010, 12:07 AM
  4. Constant Power to power window switch
    By stockies in forum Electrical Wiring / Questions
    Last Post: 02-05-2009, 08:14 PM
  5. Desperatly Seeking Power + Power + More Power
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 10:28 PM
