Results 1 to 16 of 16
Thread: Question about the dual 15" L7 Kicker Subwoofers
    VS Acclaim
    Dec 2010
    Default Question about the dual 15" L7 Kicker Subwoofers
    It is recommended on the Kicker Website that the Dual L7 Sub-woofers should be powered by a Kicker ZX2500.1 Amplifier... Here's what I do not understand as I'm new to the "technical terms" Of car audio
    L7 15" Sub-woofer is Rated at 2000/1000 Peak/RMS respectively
    the ZX2500.1 is a Class D mono-block 2500 RMS amp at 2 Ohms
    Now I'm no mathematician but the subs are 1000+1000 RMS = 2000 RMS.. the amp is 2500 RMS.. (Also all kicker amps are under rated so its more like 2701 RMS.)
    Now here is my Question.. Wouldn't it blow the sub-woofers running off that amp?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    No. This is called 'headroom'. You can not have an amplifier that is too powerful, you will just have a lot of headroom. Provided the gains are set accordingly, everything will be fine. You could potentially run a 150wrms sub on a 1500wrms amp and its fine. I used run 250wrms through my front splits with almost zero gain, and its fine.
    When you have headroom, the amplifier does not have to work as hard to power the speakers / subs. So its a good thing
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Also Kicker don't have a 2000wrms amp, so they went the next size up. Did you think they would recommend a competitors amp
    Ronald Reagan (1986)
    VS Acclaim
    Dec 2010
    Quote Originally Posted by acarmody View Post
    I didnt say they have a 2000 RMS amp, I said they have a 2500 RMS amp
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Read the post again he said Kicker don't have one so they suggest the one closest that they have which is 2500W
    VS Acclaim
    Dec 2010
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Will be fine mate. Always good to have a bit of head room. Can't think of any thing else that would suit that would be lower priced. You could contact the audio seller Joe Bellisimo before you commit though? He's a site sponsor I believe and might give you some options.
    VS Acclaim
    Dec 2010
    I want a full kicker system... If I waited like 2 monthes I could get 6 18" Solo X subs with 2 Kicker warhorse amps, But that might be a bit much
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Oh well in that case sure it will work fine and you know you won't even be stressing the amp
    VS Acclaim
    Dec 2010
    Aug 2004
    Quote Originally Posted by VSkickers View Post
    and two 1000watt rms 15" subs isnt????
    VS Acclaim
    Dec 2010
    Well, the 18's are 3000 RMS each.. So Yea this isnt that much compared to that
    91 vn s
    Jun 2009
    Adelaide, SA
    please... do it. Get the 6 18s with the two warhorse amp. How in gods name do you intend to fit 6 18s into a VS?!
    Nic92's Avatar
    Nic92 is online now Rough As
    2002 VYS S1
    Mar 2011
    WA
    your question at the start seems a bit silly if you intend in getting a big system, come on you should know this stuff
  15. #15
    SuperSixty6's Avatar
    SuperSixty6 is offline Alto Rullo
    Landcruiser TD
    Dec 2008
    Brisbane.
    Don't get too excited about 'Kicker amps being over rated'. I thought they would be under if anything...
    Your rating for the amp is 2ohms, Depends on which subs you are choosing too. As they make 2 and 4 ohm options don't they ?
  16. #16
    VS Acclaim
    Dec 2010
    Ill be doing the 2 ohms and im getting another car obviously haha
  1. [VIC] Kicker Dual 12" Subs + 22" LG LCD monitors
    By anarklov3r in forum Parts And Other Items For Sale
    Last Post: 31-01-2011, 10:28 PM
  2. Replies: 18
    Last Post: 21-02-2010, 12:46 AM
  3. 2 x 12" kicker ex subwoofers in sealed box
    By Choony in forum Parts And Other Items For Sale
    Last Post: 21-06-2005, 06:29 PM
