Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: how to Dynamat the boot of a vy
    Nic92's Avatar
    Nic92 is online now Rough As
    2002 VYS S1
    Mar 2011
    WA
    Default how to Dynamat the boot of a vy
    hey guys,
    so i want to get some dynamat, and im just wondering where do you put it, like do you dynamat the "whole boot" like on the sides and back also on the floor under the carpet, or will it be enough if i just put it on the lid of the boot and the top under the parcel shelf??
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    If you got the money than I would do the whole boot. Other wise just the boot lid and the parcel tray would be a good start.
    Here's a hint that I learnt, don't try to press it down with bare hands, the aluminum shreds your skin, my hands looked very emo after that day.
    Ronald Reagan (1986)
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by acarmody View Post
    hehe the one i want to buy is DYNAMAT XTREME BULK PACK 9SHEETS (36.0 Sq. FT TOTAL) it comes with a free roller
    umm, can you show me some pics of it??
    so if i do the whole boot i gotta like rip all the carpet out and dynamat it ?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Why are you interested in getting Dynamat? Do your panels rattle and buzz with music? That's the main reason for fitting Dynamat. If you're doing it to reduce road/exhaust noise through the boot, then it's not really the best product for that.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    umm, if you've seen my vids you'd know
    like the noise form the rear parcel shelf vibrating when your tryen to lisen to clear bass >.<
    VY SS
    May 2011
    Auckland
    I'll be looking at this soon.
    Id def do the parcel tray and the steel behind the back seats, that's gotta resonate.
    I wont bother with much of the boot though. Maybe some in the middle of the side panels and the lid.
    Are you going to do your front doors?
    VZ SS
    Jan 2011
    Down under
    if you buy a bulk pack you should have enough to do the whole boot. What about your doors, there are some excellent gains to be had with dynamat in your front doors to help reduce the rattles.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    umm idk, if tehres enough id use it all up if i can. id have to rip the carpet out wont i? to do the sides and behind the seats? or can i just put it on the other side of the emtal panel right behind the seats or it wont do anything? has to go where the amps are?, there gonna be in the way aswell
    SuperSixty6's Avatar
    SuperSixty6 is offline Alto Rullo
    Landcruiser TD
    Dec 2008
    Brisbane.
    Quote Originally Posted by StoneX View Post
    Quote Originally Posted by Nic92 View Post
    [EDIT] Wont say too much, OP will probably have a cry.
    Stop posting USELESS threads and do some google search, I have told you before read up about Dynamating and purposes, Once you actually understand it's purpose you will be able to tell yourself where it is needed.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    can you please give me a link to info?, i looked on there website and got a bit confused
    i know where i am going to put it, just really cant be stuffed ripping any carpet to strap it on meh!,
    alberts car stereo told me to buy it then they told me there price and i never went back there soOoOo.
    is this correct?
    " Sound deadening products like dynamat add mass to the panels that they stick to, making them heavier, so it is harder for them to vibrate and therefore color the sound coming from the speakers. Using them gives you a purer sound because it comes only from your speakers. [Dynamat] works great for that purpose.
    Then there are closed-cell foam products, like ensolite, that absorb sound from the outside, and make the inside of your car quieter.
    Another problem in cars is rattles. Two panels whacking together causes rattling, plain & simple. This can be solved 100% by putting something soft in between the 2 panels where they make contact. My favorite thing to use is foam tape. Cheap, effective, easy to apply. You can also put dynamat or whatever in between the panels if you're just determined to spend about $100 too much. Or you can get ghetto, & stuff an old shirt or towel in there. They all will work. "
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You need to separate the parcel shelf from whatever it's rattling against. Usually rubber or foam is a good option to separate two vibrating objects. Generally, Dynamat is just to add weight and damping to flat metal panels.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Step 1.
    Apply dynamat.
    Step 2.
    Bang seven gram rocks.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    Landcruiser TD
    Dec 2008
    Brisbane.
    is this correct?
    Sounds on track, I guess it's a pretty simple way of putting it.
    I have not done to much testing with VY's and rattleing, So i cant tell you all the specifics.
    Like you are planning though, Boot lid itself is a great place to start. Having the least amount of structure with quite a bit of sheet metal. Rear quarter panel out skin maybe another place, Not the actual internal piece but put your hands in and it's another place where sheet metal is high with little structure for added mass. I have noted that the parcel shelf trim itself seems to vibrate like crazy, Preferably some dynamat on the bottom of this and secure it down with a better locking system maybe an idea.
    Aside that, Ýou can never have too much dynamat, It wont do any harm. Just depends how much you want to strip the car, Your budget and how much gain you are set to except.
  15. #15
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    If it'll make it easier for you, Autobarn sells a Dynomat 'boot kit" for like $300ish
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
  16. #16
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by SuperSixty6 View Post
    ok thank you very much ^, umm yeah might as well use it up since im buying a bulk pack (if i do end up getting it)
  17. #17
    Oct 2009
    S.E VIC
    Just a few things you'll notice once you cover up the back, the front two pillars rattle aswell a fair bit from mine so I can only imagine it's louder with yours.
  18. #18
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I use this
    CAR SOUND DEADENING DAMPENING BULK MAT + DYNAMAT ROLLER (eBay item 330564023217 end time 23-May-11 10:17:08 AEST) : Cars, Bikes, Boats
    I couldnt tell the difference having this & dynamat side by side really, Apart from logo, I guess...
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  19. #19
    Oct 2009
    S.E VIC
    Quote Originally Posted by HoZy View Post
    I use this
    Jeez it's pretty cheap, seems like something I should snatch up.
  20. #20
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  21. #21
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Goodluck ^_^ It made one hell of a difference for both audio an how the car felt when opening & shutting doors an boot an tapping on it, depending where you put it
    I'd suggest rubber o rings, lots of acetone free adjesive/sealant in caulking tubes, aka sikaflex or bostik sealant,
    Put it inbetween your boot braces & boot lid, lots of it, Dynamat over it once it has cured an your boot skin wont vibrate/come loose from the braces.
    Even thin bits of rubber on pieces that rub, You go to extremes to stop rattles. It's best when you cannot see what you have done either.. I have near none, now days.
    Mat
    EDIT:
    Boot after all sealant cured an then I dynamatted, that was before I finished an did the top section etc. an put silicon tubing around the boot release an heatshrinked it to prevent rattles.
  22. #22
    Oct 2009
    S.E VIC
    Do you need the roller or would it be fine with some thick gloves O.o?
    edit: Looks like a normal paint roller to me...
    Is that the only spot you fitted it? Or did you end up putting it behind the carpet on the walls of the boot and in the tyre well aswell?
  23. #23
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    It's a wooden roller, You dont really need it, i did it with the back of a thick screwdriver an some spare wood i rounded off, roller would be easier but yeah. You make do.
    Mat
    P.S- my boot lid is pretty now, that pic is a while back
  24. #24
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  25. #25
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Yeah, hands and the butt of a screwdriver was all I used. You can use your hands mostly, just use common sense and don't slide your fingers along the edge of the sheets as the aluminium layer can cut you.
  1. Dynamat
    By marcdon in forum Car Audio
    Last Post: 24-03-2010, 08:09 PM
  2. Dynamat??
    By Robbo VS3 in forum Car Audio
    Last Post: 09-10-2009, 12:38 AM
  3. WTB Dynamat
    By dawg in forum Swap / Wanted to Buy / Trade
    Last Post: 18-05-2008, 04:30 PM
  4. Dynamat. 11/10.
    By VNCalais98K in forum Car Audio
    Last Post: 20-02-2007, 08:27 PM
  5. Dynamat
    By 4PLAYN in forum General
    Last Post: 12-09-2006, 09:25 PM
