Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By KAL SPL
Thread: VZ Blaupunkt not turning off with door open
    VZ Berlina
    May 2011
    Adelaide, South Australia
    Default VZ Blaupunkt not turning off with door open
    My VZ Berlina (stock 6-stacker) doesn't automatically turn off when the door is opened.
    At first thought it could have been a door sensor problem, although when I pushed the door sensor in, I could hear the relay switching and interior lights turning on/off. Just to be sure, I swapped the passenger and drivers sensors.
    I have also been through the menu and changed accessories between door and ignition. Also when the head unit is switched off, the screen is always lit. Any thoughts?
    vz sv6
    Jun 2010
    Default same dea
    hey mate i have the same problem started to weeks ago also cant find a fix a bit odd tho
    ss
    May 2009
    This is an internal issue with the unit...some of the SMD capacitors go resistive and cause it to stay on.
    Take it to a good technician and they should be able to rectify.
    VZ Berlina
    May 2011
    Isn't the head unit, I've tried a Pioneer and Sony head unit, both get power and can eject/load discs but won't actually power on. Will be taking it to a Holden Dealer/Car Audio installer when I get some time.
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    i like you kal spl seen this many times the door setting wont take control of radio power UNTIL ignition is in off position...
    new ignition switch (left side of steering coloumn opposite ignition barrel) OR broken shaft on ignition barrel
    the switch has an on off spring loaded part in it that sometimes (with age) sticks and doesnt pop out when key removed
    VZ AWD One Tonner
    Jul 2006
    Do you guys have anything plugged into the cigarette lighter?
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    esca_ByDesign's Avatar
    esca_ByDesign is offline Clean and Classy
    VY exec By Design
    Jun 2009
    Croydon Hills
    Quote Originally Posted by turbocorty View Post
    SMD capacitors? so its a surface mount diode capacitor? lol
    Quote Originally Posted by WogBoyz View Post
    So if i dont wax my car, ill never get dust on it? gotta try this one!
    Looking to buy VE super sport replica's
    VZ Berlina
    May 2011
    Thx for the replies guys, was thinking possibly the key barrel, thanks for the tip KAL SPL.
    @gslrallysport, nothing plugged into the cigarette lighter.
    ss
    May 2009
    Quote Originally Posted by esca_ByDesign View Post
    SMD Surface Mount Device
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    VY exec By Design
    Jun 2009
    Croydon Hills
    surface mount device capacitor still doesnt make sense.
    ss
    May 2009
    Your funny!!
    VY exec By Design
    Jun 2009
    Croydon Hills
    Your funny!!
    logical
    10 characters
  15. #15
    ss
    May 2009
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Try this before you spend any money on a fix. The same thing happened to me a few months ago. It was the door light switch on the driver's door failing to earth out when the door was opened. This earthing is what cuts the audio off when the door is opened.
    I noted that you have swapped the switches over from both front doors, but it still might be an earthing problem. Just remove the driver's door light switch, clean up the contacts and mounting screw and reassemble. Let us know if it works for you.
  1. Door won't open
    By Taddy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-12-2008, 12:46 PM
  2. Somebody try steal or try open door my door, which alrams best for vs???
    By MimoVS97 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2008, 10:25 AM
  3. Door will not open.
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 09:36 PM
  4. How To Open Door
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 09:28 PM
  5. back door will not open
    By karter13 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2005, 07:07 PM
