Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: HELP!!!! lost all sound in my car!
    VT Executive S2
    Apr 2011
    Rockingham
    Default HELP!!!! lost all sound in my car!
    Hi, dont know whats happened but i was driving along yesterday with the sound up fairly loud when all of a sudden it all just stopped, no bang or pop or sizzle, just nothing! now i cant get any sound at all... my headunit still lights up and works perfectly but nothings coming out
    I am running 2 JL Audio Subs with a Class D monoblock 1400 and a 480 watt 4 channel amp
    I have check all the fuses and its probably a very straight forward answer but any help is appeciated!
    thanksHELP!!!! lost all sound in my car!-img_0235.jpgHELP!!!! lost all sound in my car!-img_0237.jpg
    Nic92's Avatar
    Nic92 is online now Rough As
    2002 VYS S1
    Mar 2011
    WA
    VY SS
    May 2011
    Auckland
    Check the voltage at the amp with a multimeter. Sometimes fuses don't look blown but are stuffed and you get next to no voltage under load
    VT Executive S2
    Apr 2011
    Rockingham
    Ill have to pick up a multimeter somewhere and check.. is there anything else that might be it, someone suggested i burnt out my amp? or something like that
    there was the faintest of burning smells when it happened but that dissapeared qucikly and now there is no smell
    VX Executive S1
    Dec 2010
    Milperra
    Check your audio cables? Are ur rc connections secured or just loose fit? Do your amps still power up?
    VY SS
    May 2011
    Auckland
    Do you have amped speakers or is it just the sub? If it's just the sub take it out of the box. If the voice coils gone it will reak
    VS Berlina S2
    Aug 2010
    This happened to me the other day. The RCA's had been broken off in the socket (bad driving on my part, sub was floating round in the boot lol), so got a new amp (couldn't get one of the RCA's out -_-) and after hooking it up lost allllll sound. HU was shorted, when i took it out to test with multimeter you could smell it was burnt. there was no fuse on my HU, bloody Schneider POS..
    anyway.
    what Headunit do you have, has it got a fuse on the back? smell anything? do your amps light up?
    VT Executive S2
    Apr 2011
    Rockingham
    JVC headunit, checked the fuse in the back and its fine, the amp doesnt power up though so its probably that, could be looking for a new amp i guess haha
    VT Executive S2
    Apr 2011
    Rockingham
    Amp doesnt power up, think thats the problem... having someone check it all out tomorrow
    VT S2 - SS intirior - Ls1 Project!
    May 2011
    Sunny coast
    Could you smell anything as staited above just after it happend/just before?
    Did your amp get hot much? no airflow is a killer..
    i know my sub did for about 10 sec before and a hour or so after.. (electrical burning) what you get from 1300 wat sub on a 5000w amp :\
    VT Executive S2
    Apr 2011
    Rockingham
    there was the faintest of smells, so faint i didnt know if it was coming from the car or outside,
    the amp wasnt warm but nowhere near hot
    VT Executive S2
    Apr 2011
    Rockingham
    It's was the fuse that connects the the battery, didn't look blown but the positive end had burnt out giving no power to the amp
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    VE
    Mar 2011
    n
    Quote Originally Posted by Nic92 View Post
    lol, that happened 2 me once, you need a bigger fuse
    No he doesn't.
  15. #15
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    A bigger fuse is dangerous.
    FInd out why the fuse blew in the first place.
    Ronald Reagan (1986)
  16. #16
    VY SS
    May 2011
    Auckland
    Your fuse size should be based on your wire size. It's to protect the wire. If you need to draw more current you need bigger wire. The fuse there should be bigger than all the fused loads that are running off it.
  17. #17
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    was it those tube type fuses? ive had a couple of them go dodgy on me b4 and all it was the end caps that came loose and lost connection giving me an intermitten cut out. it did leave a bit of burn on the wire due 2 it arcing wen it made contact, mayb thats all urs did?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  18. #18
    VT Executive S2
    Apr 2011
    Rockingham
    yeah it was the tube fuse, the guy said that the ends tend to burn out giving no power while leaving the actual fuse looking fine. I had a 60 amp fuse in, the guy suggested an 80, should i go with the eighty or stick with the 60?
  19. #19
    VY SS
    May 2011
    Auckland
  20. #20
    VT executive
    Sep 2009
    Essendon
    i have the same problem i blow mine very often i would say ive blown between 25-30 fuses ive had it checked over quite a few times had it completly rewired still does it
    Get on it!!
  21. #21
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    Mines running on a 150AMP fuse (came with 120AMP in the kit but it blew from short-circuiting and had none left) and I'm running 800WRMS into 2 ohm. I suppose if you're running half the power you'd need half the size fuse.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
  22. #22
    VY SS
    May 2011
    Auckland
    Your wire size determines the size fuse you need. Your amplifier power then determines your required wire size. 150a for 800rms sounds way too big. I hope it's decent sized cable
  23. #23
    95 VR V6 Turbo Ute
    Oct 2009
    Sydney, North Shore
    I am having the same problem as first stated. Basically;
    Other night, was replacing a switch for my driving lights, had acc. on, listening to stereo. Then turned it off to go inside for bit, then turned it back on and no sound.
    Have checked all fuses, everything has power.
    Set up runs as follows:
    Battery>Fuse>Amp
    I am mighty confused, have checked connections on amp with multi, getting 12v thru remote with acc. on, but nothing through B+? Never checked before, is this normal? The LED on the amp is on and so is the head unit.
    Have tried different RCA's, disconnecting sub, everything I could think of, looks to me like amp is dead.
    Didn't touch any wiring to do with the amp or anything. Am going to try a different amp in next few days, mean while any suggestions would be helpful.
    Thanks
  24. #24
    VY SS
    May 2011
    Auckland
    B+ should have 12v at it. Fuse is probably blown. They don't always look blown. Take the fuse out and measure the resistance across it.
  25. #25
    wrx884's Avatar
    Mar 2006
    r use ur DMM and check 4 continuity on either ends of the fuse, then fuse holder.
  1. power steering made popping sound and lost all fluid very fast.WTF
    By mattyr82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2010, 07:12 PM
  2. sound system help, sound changes in middle of song!
    By Summer-Sickness in forum Car Audio
    Last Post: 13-04-2009, 02:54 PM
  3. Sound System high pitch sound
    By liquidforce_134 in forum Car Audio
    Last Post: 16-07-2008, 10:31 PM
  4. just bought sound system, will it sound good
    By pier_one in forum Car Audio
    Last Post: 02-10-2005, 01:27 PM
  5. Lost 2nd And 4th
    By menzy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2003, 09:41 PM
