Hello All
im looking to get some speakers for my Vy ute
i would like to know the maximum size speaker i can put in the door (ie 5.25" or 6")
i would also appreciate anyone who can tell me the maximum mount depth on the door speaker.
could anyone give me a link that would show me how to install them in to the doors?
Thanks for your time![]()
I'm running 6.5" with a 3" mounting depth, all good. Though anything larger than 6" you'll need to modify the stock speaker mount a little bit. Pretty well any 6.5" speaker will fit in the door though.. what are you looking at?
tossing up between
JL AUDIO C2-600 6" or POLK AUDIOŽ MM5251 5-1/4"
just the sound quilty jump up that much if you go to 6.5"
Not so much sound quality mate, midbass is huge. I rate the Polk MM but the 65 series, its worth going for the 6.5" for sure, 5.25 is too small for a commodore door anyway.
ok if i use the 6.5s
how do i install them have you got a link?
im putting a polk 12" mm sub in as well
once agian tossing up between 10" or 12" i hope bigger is better
with this system im going after sound quality not power
Thanks
