Hi all
I have the Maestro radio system in my Calais and only get the sound playing down the drivers side speakers front and rear and it is the same deal with the 10 cd stacker also when I play CD,s
Any ideas guys??
Cheers Mark.
push the volume button in you will be abel to set base, treble, and also fade (front to rear) and balance (left and right) make shoure all are ste to the center. hope this helps
Thanks I will try that.
No that didn't fix the problem.
Thanks for you suggestion though.
Take the door card off and check passenger speaker is connected.
Thanks mate I've got a day off this week I'll take a look then.
Cheers Mark.
i had the same problem with my old vt i had,
turned out it was one of the wires in the loom had worked loose from the plug,
if all else fails, check the plugs and the loom,
good luck
Thanks for the good advice fellas.
Finally got the time to take off the the door panel and found that the plug on back of the speaker had worked its way off just enough not to make proper contact.
Just vibrated loose is my guess due to the low profile tyres and crappy roads.
Was my first time removing the door panel and I was a little worried I'd stuff it up so I went and bought a haynes book and all went well
No extra bits left over lol. as is usually the case with me
Thanks again cheers Mark![]()
