Wanting to put new speakers into my VY, but i dont know what size speakers to buy?
Help please![]()
Slammed 5.7 VY calais II tuckin G8 20'z
6" indeed, though 6.5" will fit pretty easily. Most tweeters are 1" maybe 2" but they all fit, so when buying coaxials or component speakers 6" and 6.5" are both fine provided you don't mind cutting the speaker mount a little bit.
Heffany did that help at all?
These two hit the nail on the head anyways, let us know what speakers you end up getting![]()
i got told from a bloke at autobarn that 6.5 will fit but need to be shallow, but im not 100% sure so dont quote me haha
My factory vy and vs speakers have been 6", 6.5" ones fit if you make mdf baffles for them. There's heaps of depth in the doorcard, just space it off the door 2 or so 18mm mdf thicknesses
Agree. I put 6.5 splits in the front doors and 6.5 coaxials in the rear doors of my VY when I had it. Just use a spacer, either make them or buy them. They are pretty cheap. They add the benefit of giving your speakers something more rigid to hold them than the door metal. Also worth putting some kind of dampening pad in when you do it all.
my VY S II has 6" front and rear with tweeters in the front near the windshield corners from the factory. fitting 6.5" splits is very do-able but does require modification depending on how deep your new speakers are. Almost certain that you will require some modification to fit them correctly.
