Results 1 to 6 of 6
Thread: 6x9 Speaker Install in a VZ
    VR Calais
    Mar 2011
    Plumpton
    Default 6x9 Speaker Install in a VZ
    hey guys im about to install 6x9s into my partners car and im not to keen on cutting the parcel tray considering the parcel tray i cut out in my vt went completely wrong and the speaker grills wouldnt fit at all
    is there a write up on here or a how to guide? iv searched but nothing comes up
    thanks in advance guys
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Do you mean the metal or carpeted plastic?
    If you mean metal it should just pop out...
    And with the carpet I grabbed a stanley knife and
    Run over the grooved outline a couple of time to weaken it
    The stabbed some old tin snips through and cut it...
    Dunno if that helps mate?
    But I found the if you stick to the groove already in place it should
    Be easier then cutting elsewhere
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    VR Calais
    Mar 2011
    Plumpton
    That's where I cut last time n the speaker grills wouldn't fit, yeah I forgot to mention I'm doing the carpet not the metal piece
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I cut mine out just inside the grooved line . Then you have to cut out little nicks for the tabs on the grilles to fit so you can bend them over to keep them in place.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    If you cut the shelf to the mounting diameter of the speaker, you'll probably find that you won't be able to screw the speaker to the parcel shelf enough to properly secure it because you won't have enough surface area.
    Just use some spacers so that you don't have to cut anything. I'd probably use a set of angled spacers so you can position them a little better.
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Grab ya grill and trace around it on the carpet...
    That should give you a rough idea of what you need to cut...
    And if you are using the grills you get from audio shops..
    DNA I think they are...leave tabs like dayvo said...
    If youre worried about them not fitting cut a little bit
    Out at a time
    My Ride
  1. VS SPEAKER INSTALL: help needed!
    By VS dream in forum Electrical Wiring / Questions
    Last Post: 20-02-2011, 07:34 PM
  2. ASR VE Amp and Rear speaker install
    By MySV6 in forum ASR Audio & Electronics
    Last Post: 02-02-2011, 08:42 PM
  3. Amp + Speaker install DIY help please
    By Jimbahh in forum Car Audio
    Last Post: 30-11-2010, 11:25 PM
  4. VZ SV6 speaker install
    By GTRwilson in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-06-2009, 01:08 PM
  5. vs speaker install, please help
    By someaussieguy in forum Car Audio
    Last Post: 08-03-2008, 03:39 AM
