Results 1 to 12 of 12
Thread: VS System
    VS Berlina/ KJ Verada
    Sep 2006
    Default VS System
    Hi guys. I have 6 inchers in the front doors and 7 x 10's in the rear and 50w x 4 deck, all Kenwood gear.
    Also over time from mates I have aquired a 10inch pioneer sub and a 4 channel mtx amp.
    What is the best way to set all/ some of this stuff up as I dont believe I'm getting all that I can from my speaker/ head unit setup.
    Also, tweeters, what exactly do they do and should I add a set in?
    Laymans terms please fella's, although I have the aptitude to set it all up with instructions, I don't know s**t about audio systems!
    Cheers, Chris
    VY Berlina V6 / R31 Skyline
    Dec 2008
    The short answer is
    Install the 4 channel amp, run all your speakers off it.
    OR
    Install sub and amp, run rear speakers off headunit and highpass filter (What model headunit do you have?) And then front channels for front speakers, rear channels bridged (what model amp?) for the sub
    Tweeters you can not just 'add in' to a system, you need to buy component speakers to start with.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    Sep 2006
    OK, so head unit model is: KDC-MP4036U thats on the cover of the manual so i guess thats it and the amp: MTX roadthunder RT404...
    I dont fully get 'bridging', lol, i would guess that i put positive an negative wire from the sub together and 'bridge' the two amp terminals with another bit of wire??
    Sorry mate, could you explain to me what a highpass filter is and what i would do with it?
    And by component speakers for tweeters u mean what exactly?
    Sorry bro, im a layman when it comes to audio but i can hook it all up !
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    wat r u specs on all the speakers u have? that amp if ur running them @ 4Ohms is only rated at 37.5rms which really isnt worth putting in ur car IMO (unless u got it free and u just want somthing a tad better then the head unit.) which may explain y ur system seems under powered.
    If u bridge ur sub with that amp u'll b gettin only 150rms which again wat model is the sub?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Dec 2008
    Quote Originally Posted by wrx884 View Post
    With the speakers, still better than the 12wrms - 18wrms the headunit would be giving.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Oops i don't know what thread i thought i was in !!
    Sep 2006
    Monaro CV8R, Landcruiser 100 Series 4.7L
    Jun 2011
    Personally I would run the two front door speakers from two of the amp channels and the rears form the head unit. I presume the sub is in a box? If so run the 3rd and 4th channels bridged from the amp to that. If the amp is bridgeable which most new ones are it is a case of taking the + from one channel and the – from the other channel that is bridgeable with it (usually works 1 & 2 or 3 & 4) and wiring them up to the relative + and – inputs of the speaker. Then switch the amps output settings to low pass or LP. Run the fronts as either full range or high pass HP.
    You will need to set the input sensitivity of the amp. Usually two small dials with a slot in them on the amp itself. To do it correctly you need to know the output voltage of your head unit but a work around is to turn them down and turn your head unit to around 2/3rds with all EQ ie bass, loudness etc flat or off. Then bring the amps inputs sensitivity levels up until it starts to distort and then back them off until its sound clean.
    Make sure you get all your polarity right i.e. all +’s to +’s and all –‘s to –‘s. Just sayin.
    Sep 2006
    Quote Originally Posted by Crisis63 View Post
    Cheers mate. Sub is in a box. Got a feeling the amp may be blown, power to the cable but when i hooked it up, nothing?!?
    Jun 2011
    Quote Originally Posted by SWE11L View Post
    check the fuse. Just sayin. :-)
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Or bad ground
    ________________________________________
    Sep 2006
    cheers boys ill look into the earth, fusees are all good!
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
  1. [NSW] Exhaust System + Lowering or Audio System
    By Gus in forum General
    Last Post: 21-01-2011, 07:55 AM
  2. Replies: 4
    Last Post: 26-01-2010, 02:31 PM
  3. [SA] Entertainment System (TV/Amp/Sound System) Selling Sep, Together OR Trade
    By boddyy in forum Parts And Other Items For Sale
    Last Post: 25-12-2009, 02:14 PM
  4. new system
    By Simonn in forum Car Audio
    Last Post: 16-08-2009, 11:55 PM
  5. VE CAN Bus System
    By muzzz89 in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-08-2008, 08:43 PM
