Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Like Tree2Likes
Thread: Kicker 08ZX350 4 Channel Amp protection light flashes
    Nic92's Avatar
    Nic92 is online now Rough As
    2002 VYS S1
    Mar 2011
    WA
    Default Kicker 08ZX350 4 Channel Amp protection light flashes
    so i installed my new head unit after it got replaced because the otehr one was faulty and on my Kicker 08ZX350 4 Channel Amp, it flashes red around every 5 seconds, any idea why ?? also it does not turn on
    thanks
    VY Berlina V6 / R31 Skyline
    Dec 2008
    What does the red light indicate on the amp? Have you checked solid grounds etc? Though considering the problem came at the same time as your new headunit, have you checked the remote wire is hooked up to the remote wire of the headunit etc?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    http://www.kicker.com/sites/default/...0d01%20web.pdf
    not overly helpful, if its a yellow light, id check conections and battery voltage
    but, id take a guess that when you fried the old headunit, it fried the amp aswell, having both amp and headunit outputs hooked to the speakers at the same time.
    disconnect all the speaker wires from the amp, and pull them fuse and put it back in, check theres power at the remote wire, and see if it fires up
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    if only i new where the shop wired the remote wire to that time wen it got installed ages ago... i havnt found a way to remove the front dash panels yet hehe
    Dec 2008
    If you can't remove the lower dash panels to check the headunit wiring, i would take it to a professional.
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Quote Originally Posted by Nic92 View Post
    erm...as sweefu said may be time to take it to a professional.
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    I would also recommend checking the fuse on the battery feed.. mine was loose last year and the amp kept going into limp mode
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    ok, yeah i was going to take it today, im going to have a little play around with the connections then if it still wont come on il take to the shop and ask them,
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    where in perth u located? if u need a hand pulling ur dash appart i could give u a hand, its quiet simple. might b able 2 trouble shoot where ur remote wire is.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    yeah that would be a good idea.. but umm i just got some fuses and stuff and now it caught on fire.. from the inside.. @ what hakhawk said i believe the faulty unit wrecked the amp, now i got my speakers conencted to the deck and it sucks balls!
    it didnt blow the fuses either just started smoking
    Dec 2008
    Man i'd really take it to a shop to have everything thoroughly checked over, sounds like you have a series of problems here.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    yeah maybe i will, i never touched the wiring to that amp when the shop installed it so. i didnt mess anything up, but umm maybe some time i will when i get some cash, they said they charge $110 an hour and i was like yeah umm il come back wen i can pay (before i changed the fuses etc etc, all they were goin to do was test it with a diff head unit and stuff) but now they will probs just say if its still under warrenty take it back to the shop just like they said about the head unit wen it was faulty
    wrx884's Avatar
    Mar 2006
    big lesson learnt here i guess, tho where r u gettin all this tested from 2 charge that much?
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    get what you pay for?
    maybe try finding a different shop if they installed it all badly...and probably dont
    mess around with stuff if you dont really know what you are doing
    My Ride
  15. #15
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    umm the shop is like the best one here, i got the job amp installed at a shop called JB Hi Fi, they charge a bit less and THEY DO NOT SOLDER the wires which i thought was pretty stupid and the shop i went to with the amp was Alberts car stereo whch are expensive but they do a really good job i have even see them work on a lamborghini i was like DAMN but anyway i dont think it is on warrenty any more because i brought it ages ago back when i was on my leaners and i havnt touched it since they installed till the other day wen it stoped working
  16. #16
    wrx884's Avatar
    Mar 2006
    Yeah but working on a lambo ppl would treat it different 2 an every day commo so they would have 2 b picky with wat they do. Not saying thats how they treat their jobs but it can happen.
    Was only last week i did a job 4 a guy that wanted puddle lights in his doors and was warning about sound deadner so i may have probs working with it. Turns out an alberts store did the work there was no deadner in the car wat so eva, drivers side speaker was done properly wiring it through the doors gromet with seperate wiring, the other side was just wired 2 the original stereos wiring :S they used MDF spacers 4 the guys splits which isnt a problem but they should b sealed. water was gettin on them some how causing them 2 start swelling. so somtimes it does pay 2 check the work thats been done, now this guy is furious coz he paid 4 deadner and 2 have a good simple job done he now has 2 spend extra fixing up the problems.
    neways check ur receipts u might b supprise it could b still in warrenty? its worth a shot.
  17. #17
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    yeah i mean wen i saw a lambo here in Morley, just looking at the car turned me on hehe na jks but u get it? umm yeah i did work experience there for 1 week with the skool in yr 10 and they have changed employers/employers but that store seem like a good place, but anyway some1 up there said i dont no what im doing ^ umm i think i do, because putting the 8 gauge power cables in and then the remote wire then putting the battery terminals in and the rca and speaker wires were out, and it started smoking so.. i believe i did connect it right.. and test it right, something is wrong with it inside, i cant go openining it up having a look in side or even the audio installers wouldnt know, its one of them things you need to take it back to the manufacturer and get there technicians to have a look at it, i am just going to buy a new amp i think, i might get a matching 1 to my sub amp then get better speakers so0o0o0o thanks ofr all the comments ^
  18. #18
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Is the power wire fused properly near the battery? And when you connected it did
    You have the negative disconnected from the battery?
    My Ride
  19. #19
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    um yeah the 8 gauge fuse/holder never touched either but yeah i checked if it was in properly, i connected it when both terminals was off the battery
    even if it is on fire inside of the amp, most likely it will not turn on without repairing it
  20. #20
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    which way did you connect the battery terminals back up? im pretty sure your supposed to go positive negative.
    also is the earth from your amp in a good place?
    and what size fuse is on your 8 awg near your battery did that blow?
    are there fuse in the side of amp? if so did any of them blow?
    Where did you get the trigger wire from? you said you didnt know how to pull
    your dash apart, are you sure its the trigger wire you have hooked up?
    I have a jb hi fi here too they go alright...I prefer wow though...Dunno
    if you have them where you are.
    My Ride
  21. #21
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by kcpwns View Post
    yeah they did an alright job but they just didnt solder the wires on the head unit when they changed it
    the remote wire is the same one that has always been on there
    the fuse is the one that came with the wiring kit and the 1 they put on there and it is not blown and idk wat A it is
    im guessing the earth would be in a good place if its been running for nearly 2 years now and i havnt had any problems with it untill the faulty head unit came and stuffed everything up
  22. #22
    Dec 2008
    Man if they didn't solder the wires when they did the headunit i'd be pushing for a refund and starting a case with Fair Trading, that is further than dodgy for 'Professionals'
  23. #23
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    mite be able to send the amp back to kicker and they may replace it?
    although from now on i would get your stuff done by a professional mate..
    it doesn't take much to blow stuff up when it comes to electricity..
    and you can put yourself in danger..
    My Ride
  24. #24
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by sweefu View Post
    yeahh they were tight thou, but still always solder if its there permanent -.-
    but umm they also connected the speakers to the factory wiring for the Blaupunkt head unit and to the amp but they didnt connect the pioneer head unit to them, they did the wiring directly to the factory ones, they didnt use any wiring harness to connect to the ISO which would have been easier
    this is how the shop conneted it
  25. #25
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    I think you've just fried your amp..same as when you fired your headunit, not much you can do bout it mate..
    My Ride
  1. [VIC] FS VIC: Kicker 5 channel amp (ZX700.5) 60W x4 +420W x1 mono- excellent cond
    By raff in forum Parts And Other Items For Sale
    Last Post: 11-04-2011, 03:39 PM
  2. [VIC] Kicker 5 Channel AMP ZX700.5
    By VZHSV in forum Parts And Other Items For Sale
    Last Post: 03-08-2010, 09:00 AM
  3. battery light flashes
    By benno9911 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2010, 09:13 PM
  4. VY Berlina Interior light flashes when door is open
    By MadDawg in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2008, 12:17 PM
  5. Hazard Light Button - Flashes
    By Sammy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-07-2005, 03:36 PM
