Results 1 to 6 of 6
Thread: subs in a standard vy ss head unit
    vy ss manual
    Jun 2011
    vic
    Default subs in a standard vy ss head unit
    ok iv got a line level converter iv got all my sub and amp wired up and powered up all i need is the right signal from the standard wiring for the head unit iv tried to use the rear speaker signals and that doesnt work right what have others done with the same head unit to get subs to pump properly
    Jonno's Avatar
    Jonno is offline :)
    Vk
    Nov 2010
    Vic,
    are u talking about the remote wire?
    just turn the car onto accesories and find a wire (with a test light that is allwase on) we used the wire coming from the electric mirror switch, spliced into it and then ran it thru the door loom and back to the amp...
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Check the sticky at the top of this section, all the wiring colours are there.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    vy ss manual
    Jun 2011
    vic
    no i dont need any of that iv got remote i know the colours all i want to know is what do i use as a signal to the converter for my sub
    2011 VE Series II SV6
    Mar 2010
    The rear speaker channel should work, there is no reason why it doesn't. B sure to connect the polarities correctly to the loc and everything plugged in correctly ie outputs to inputs n so on. Sorry don't mean to say u dont know what your doing but there just shouldn't b a reason why the rear channels don't work. Check the fade on the deck.
    Cheers.
    vy ss manual
    Jun 2011
    vic
    ok so it was a polarity issue all good now working fine would you recomend using both rear speakers to even out the drain or do people usually just use one side
  1. subs in a standard vy ss head unit
    By vyss manual in forum Car Audio
    Last Post: 26-06-2011, 08:09 PM
  2. VY Calais factory head unit & subs
    By CARUNA in forum ASR Audio & Electronics
    Last Post: 08-04-2010, 08:51 PM
  3. subs and amps with stock head unit on a vx
    By club255 in forum ASR Audio & Electronics
    Last Post: 26-10-2009, 11:07 PM
  4. amp and Sub through standard blaupunkt head unit
    By mat vsII in forum Car Audio
    Last Post: 30-06-2008, 09:45 AM
  5. VZ head unit+subs+amps, how do I do it?
    By HAREBA in forum Car Audio
    Last Post: 18-03-2008, 12:54 PM
