Results 1 to 8 of 8
Thread: SV6 audio upgrade questions
    VE SV6
    Jul 2011
    Victoria, Australia
    Default SV6 audio upgrade questions
    Hi all, i am new to this forum so please dont be too harsh on me!
    I am thinking of putting a full Alpine Type R system with one 12 inch sub in the boot, but have a few questions for all the audio freaks out there.
    Heres my plan:
    In the front doors: SPR-50C 5 1/4" Component 2-Way Speaker (with the tweeter components in the dash)
    Rear doors: SPR-50 5-1/4" Coaxial 2-Way Speaker
    Boot: SWR-1243D 12" Subwoofer
    Ok, it seems to me that the speakers are 5 1/4" but will 6.5" fit onto the existing mounts? If so i'll opt for the larger 6.5" speaker.
    And Will the tweeters be a dog to fit or is it a matter of screwing them into a the same position where the original dash tweeters are?
    Anyway what do you all recon of the speaker setup?
    Share
    VE Commodore SV6 Series II
    Jun 2011
    Dubbo
    Hi mate,
    The 6.5" speakers do fit so defs use them over the 5-1/4", the Typre-R subwoofer is a great sub good bang for your $ but make sure its vented (i think thats what they call it) means there is a hole for the air to flow from so the bass is louder and hits harder basically. The tweeters should just sit in the same place as the factory tweeter, there will be a screw holding the factory one but the alpine tweeters dont have a mount to sit in so i just wrapped thick double sidded tap around the edge of mine and stuck it in there and it was all sweet.
    Overall the setup sounds sweet as long as there is a amp in there somewhere to power it all
    VE SV6
    Jul 2011
    Victoria, Australia
    Oh nice, I was hoping they would fit! Ok, will remember that when buying a sub box. So the tweeters will fit and no holes cut in the dash? (ive seen some dodgey work :/ ). Mm i dunno what to do about amp. i know you need a lin out converter, then an amp.. but i recon ill leave it to the shop to work out when i go to get it all installed.
    thanks for commenting
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    yeah mate if your unsure let the shop do it...Ive seen some dodgy stuff lol..
    At least you know if it stuffs up they will have to fix it
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Quote Originally Posted by adam sv6 View Post
    Heres my plan:
    Share
    Have you bought all this gear already?
    Whats your main aim with the stereo?
    What amplifier(s) are you using?
    How are you planning on running amplifiers with the stock headunit? Processor, LOC etc
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VE SV6
    Jul 2011
    Victoria, Australia
    Quote Originally Posted by sweefu View Post
    I havent bought it yet, as i didnt know whether 6.5 inch speakers would fit, but will slowly start buying everything. Main aim of sterio is quality, louder as well, but not retarded like can hear it from next suburb. Im planning to use factory hu, then run it to a loc, then to an amp (correct me if im wrong, im not sure about that part). As far as brand of amp, ill stick to alpine for the sake of keeping it all the same, but will let the shop do the calculations for which one to get. Have any suggestions on amps or loc's??
    VZ SV6
    Sep 2009
    Cessnock, NSW
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by cjw.891 View Post
    just a question fella's, is it easy to get to the tweeters and how?
    Please don't thread hi-jack. Also, learn too use the search function, there's a heap about this already.
    Here's a good guide with some pictures Tweeters
    The bracket that holds the tweeters is screwed to the dash very tightly. I found using a lot of downward pressure on the screw helped it to come loose. Whatever you do, do not strip the screw. You'll know which screw I'm talking about when you get to it, in a bitch of a place because of the window.
  1. SV6 audio upgrade questions
    By adam sv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-07-2011, 07:52 PM
  2. Ve ss ute audio upgrade
    By vessbronco1 in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-01-2011, 06:02 PM
  3. VE Audio Upgrade
    By Skitz0 in forum Car Audio
    Last Post: 23-11-2008, 09:52 AM
  4. VS audio upgrade.
    By Trei in forum Car Audio
    Last Post: 10-05-2007, 09:49 PM
  5. ute audio upgrade
    By ss kev-vz in forum Car Audio
    Last Post: 08-12-2006, 04:52 PM
Tags for this Thread
