Helloo, was just wondering if somebody could shed a bit of light on my situation for me.
i have a 2x 12" subs, running off a 1800w amp, i have been given a 350w amp from a friend.
my problem is, i want to run the rear 6x9's off the 350w amp, but im unsure to go about it.
can the 6x9's connect straight into the amp, then run a wire kit for the amp to the battery/headunit?
so the speakers can be discounted from the headunit and connect to the amp?
thanks dan.
Starin at the world through my rearview
Go on baby scream to God, he can't hear you
I can feel your heart beatin fast cause it's time to die
Gettin high, watchin time fly
what type of amp is it?> brand and model? also what head unit are you running?
sony xplode amp, and just some kenwood one, not sure what type.
can only certain head units run dual amps?
need to know how many rca outputs is on the back of it will determin how many amps you can hook up via rca
also if the amp that is running the subs, if that has a rca output on it for another amp, could use that if there is only 1 output on the head unit
or you might need to use line out converter to rca
As said if you can at least come up with a model number for the headunit would be good. You can run a separate power lead etc for the other amp. Piggyback the remote wire. Worst comes to worse get an rca splitter.
As has been said, OP you need to provide more information before anyone can properly help you.
Hey sorry about late reply, my model of headunit is
Kenwood KDC-MP4039
Thanks Dan.
Get RCA cables, run from the pre-puts on the first amp, and connect to second amp. Connect 6x9"s to the second amp, run power to second amp. Done.
Ronald Reagan (1986)
thanks heaps everyone, was very simple.
