Page 1 of 2 12 LastLast
Results 1 to 25 of 49
Like Tree11Likes
Thread: audio = 100ks less per tank??
    2003 VY S II
    Jun 2011
    Bulleen
    Question audio = 100ks less per tank??
    hey guys and girls, about a month ago i installed a half decent audio set up in my VY S II and since then i have noticed my distance travelled per tank has dropped a fair bit.
    i always fill up with 95 fuel, i used to get anywhere between 450-560ks per tank before i would fill up depending on how "interesting" i made my driving haha.
    after the sound went in im only getting low 400's - 460ks per tank which is really sad for me so if anyone can help out why that would be great
    cheers guys and girls of just comm!
    Nic92's Avatar
    Nic92 is online now Rough As
    2002 VYS S1
    Mar 2011
    WA
    i have no idea lols, maybe the alternator is more stressed to power the audio, which uses more fuel, like using more acceleration to charge quicker, idk its only my guess im probably wrong haha, good thread thou, i think there was a thread while back on this topic
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Quote Originally Posted by revhead2011 View Post
    What is in a half decent audio setup? I'd say its a coincidence. The only real thing could be a little more fuel consumption due to more strain on the alternator, but that should only be if you are running something to massively drain current (300amp plus draw) which is highly unlikely. Or the extra weight which again, would be fairly unnoticeable unless you have a few hundred kg of stereo in there, which again is unlikely. What components are you running? May as well ask.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Your alternator doesn't have a clutch so is active all the time so I fail to see how it can be the cause. What it most probably will be is you not keeping an eye on revs etc while your driving.
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    How much does this set up weigh? Adding even 100kg would throw out your consumption a little.
    Dec 2008
    Not 100km per tank.
    Holden VZ
    May 2011
    Hahha this is such a funny thread!
    How much does it weigh? That could be a issue
    Maybe also with your blasting sound you are now driving with your window down making sure everyone can hear an this is creating wind drag?
    Goodluck! This seems crazy
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    VY S/II S Pack
    Apr 2011
    Fully sick subwoofa = tough as driver = lead foot = more consumption? Ayyyyeee.
    In all seriousness, have your driving methods changed since installing the system?
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by Nic92 View Post
    MAG00 sounds stoned LoL.
    All these car audio threads have driven him to it.
    VY S/II S Pack
    Apr 2011
    That was the general idea haha
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    I have 2 suggestions.
    1. How much does the system weigh? This could account for part of the decrease.
    2. In order to install the system would would have needed to disconnect the battery, which would reset the ECU. I remember that with my VX whenever I disconnected the battery for an extended time the ECU was reset or whatever and for about the first tank of fuel it would drink more.
    2003 VY S II
    Jun 2011
    Bulleen
    wow wasnt expecting so much feed back but thanks everyone for your comments and wow there are some funny ones in hear hahaha!
    ok,
    my sound system does not weight +100ks lol
    im running:
    - alpine cda117e headunit
    - JL front components c2-600
    - JL rear 2 ways c2x-600
    - JL 5ch 700Wrms amp
    - Polk MOMO 12" 425Wrms sub
    - dynamat in front doors and boot lid
    - custom ported box (big btw, takes up half the boot but not that heavy, pics on "my ride thread")
    at first i thought it was the alternator, but then i quickly threw that idea out the window cos the alternator is being powered by a pulley which is driven buy the engine revs which can only change with my foot, not my sound system.
    i know all about this learning computer in the vx/vy onward commodore models and it should not effect my fuel that much. i have filled up at least 6 times since the stereo so my car has had plenty of time to "re-learn"
    and i do like to have fun occasionaly il admitt that so revs can get pretty high, but only sometimes!! not all the time!! i seem to look at my revs alot while i drive, car tends to change into 2nd at 3-3500 rpm when i leave the lights and 2-3000 rpm for every other change depending on how hard i push my foot down.
    im really confused about this fuel thing, im one line off the half way mark atm and im sitting at mid 200Ks so far which is good but... i have been doing alot of continuos high-ish speed drives along highways and through 70+km/h zones lately so il keep everyone updated as to how many ks i get to this tank.
    thanks for all the input, keep it coming!
  15. #15
    Dec 2008
    I'd rule out the stereo as the cause of your bad fuel consumption mate.
  16. #16
    2003 VY S II
    Jun 2011
    Bulleen
    Yeah, I'm hoping outs not my stereo because if it is that would be pretty stupid. It had just occurred though just as it was all installed do just throwing s possibility out there.
  17. #17
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    i get 3-350 around town! sound system and all do i have the same problem.......actually now that i think about i like boost whine right foot is to blame for me
  18. #18
    2003 VY S II
    Jun 2011
    Bulleen
    Well of I had a supercharged v6 I guess I would have that problem too haha, but I don't so it must be something else
    Sent from my GT-I9100 using Tapatalk
  19. #19
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
  20. #20
    2003 VY S II
    Jun 2011
    Bulleen
    Bahaha what the hell is that lol. Anyone who believes in that crap should honestly not item a car haha
  21. #21
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
  22. #22
    2003 VY S II
    Jun 2011
    Bulleen
    Ok, I filled the car up to day. I was suprised to see that I got 480ks to this tank but... I had to drive like an 80 year old woman to get that? I never used to drive like that and I would see 500ks sometimes before filling up. I don't know what had changed to effect my fuel like this??
  23. #23
    VE
    Mar 2011
    n
    Mate, seriously. Just listen to your ipod, and turn the thing off for a tank and measure the difference.
    Anyone who thinks the alternator's load on the engine doesn't change because the alt is not clutched is, well... wrong - or worse.
  24. #24
    VT sedan
    Jan 2011
    Lexton
    i highly doubt it is the sound system unless as most people have said your foot gets heavier when listening to music that gets you pumped up, but also the large power being drawn could be a problem... possibly.
    An alternator is just a coil of wire and magnet basically, As you increase the power being drawn, the alternator becomes more difficult to turn, ( F=NxBxIxL ) and therefore the computer needs to put in more fuel to turn the alternator at the same rate. This means you don't need to be putting you foot down for it to be using more fuel.
    Maybe invest in a capacitor? like i said i'm not 100% sure but large current or power being drawn can result in larger fuel usage.
    sorry if i'm wrong but just a suggestion/thought
    __________________________________________________ __________________________________________________ _________________________
    Dman's vt exec', 19" vanquish rims, Bagged at the rear , custom boot, 2x 12" subs, tv, xbox360, custom purple interior, dash, seats, door trim, tinted
    http://forums.justcommodores.com.au/...-dmans-vt.html
    Future mods: lowered front, Gto Bodykit, 12mm Plenum spacer, 25mm Manifold insulator, Custom CAI,
  25. #25
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by DmanVT View Post
    I love misinformation. Please enlighten me how the alternator can cause more strain on the belts when it's spinning at a fixed rpm in accordance with the motor. I'm pretty sure if the tension changed even just a little bit it would throw everything out of whack.
  1. Audio - AUX IN audio hiss/buzzing noise issues ? VE 2007
    By goldvn05 in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-05-2011, 01:19 AM
  2. Replaced standard fuel tank with long range tank..Now car keeps cutting out
    By bj42turbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2011, 09:57 PM
  3. 1998 vs statesman v6, 80l Fuel Tank into VN V6 with standard tank
    Last Post: 19-03-2011, 07:30 PM
  4. Drop Tank.. Lowering Petrol Tank..
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 05:52 AM
  5. [NSW] F/S overflow tank,surge tank ,breather tank
    By vpcalais6 in forum Parts And Other Items For Sale
    Last Post: 17-07-2009, 08:09 PM
Tags for this Thread
