Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: Amp w/switch
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Default Amp w/switch
    Alrite, So I park up and listen to my tunes so the radios running and Im gathering my Amp+Sub is still on.. Though I contol the settings Via the headunit.. I dont believe its fully off and still draining alittle bit..
    When I bought the Amp + Wiring kit, it came with a bunch of wires.. Figured most out... and had a spare left over..(Which i do believe was for the 'remote') Part of the RCA cables it had a 3rd wire stuck to it.. I used that as my 'remote' for connecting H/unit and Amp.. had no problems..
    So Ive pulled apart my car and put in the other cord I didnt use before..
    What I want to do is.. Add a switch to the 'remote' wire so I can cut the power to the amp when I park..
    Would this Turn the AMP off? and will I lose any quality sound?
    86 VL
    Jun 2011
    Canberra, Australia
    Nah it won't do nothing to ur sounds mate I've dun it before n had no change. The remote wire is using the h/unit as a switch pretty much
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Add a switch to a sub amp? so u can still listen to tunes but sub is off.
    Or u want to put a switch in to turn off a amp when h/u is off, if thats the case the amp is already off if the remote goes to the remote in on the amp.
    When u turn sub off thru the headunit menu, its just cuttin the signal to the amp, amp is still on.
    If u just wanna turn off sub amp off while on radio u can just wire in a switch inline with the remote, but switch may break eventually due to the current.
    Would have to be a good 12v switch, or hook up a relay n use the switch to control ground for relay
    ________________________________________
    VY SS
    May 2011
    Auckland
    You don't need a relay. Remote wires draw very low current (milliamps). Most switches are up to this job.
    GothicKidd's Avatar
    Dec 2010
    South Australia
    vx s pack II
    Jan 2010
    aLKIDA
    You dont need a relay or a heavy duty switch for the remote wire the current is only milli amps alomost any half decent switch will do.
    Also either way you will be drainng the battery with or with out the sub on.
    But less with the sub off.
    You could also wire it up when IGN is on then the amp is active and when ACC is on the amp will be off throught the remote wire of course.
    No switch no problems but you will loose control over the amp if you go this route.
    VY SS
    May 2011
    Auckland
    That's how mine is. By accident but works great.
    Sub only goes on 2nd click
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Ive stuffed the cheap jaycar red illum button switches on remote after a month, only got switched a couple times too.
    I Doubt a missle switch would break tho, ive had one of those last 6months on thermo fan positive before it fried
    Im sure they put out more than 1/2amp current
    Relay is the way, and good for future amps being added n not having to worry about drawing too much from the remote wire/head unit
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Yeah I was thinking about the IGN wire, but it was just added the switch and its perfect... Doof Doof to _________ in 1 click
    cheer
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by calais_cruzin View Post
    If the switch current limit is lower then the supply current then yes it will burn out. But if its well over or with in spec you will have no problems.
    Also if you want to be sure see how much current the remote wire is giving out. Use a multimeter in sereise on amp mode.
    If you were to run extra loads from the remote wire then i would use the relay but it is a safer option but the switch will work fine aswell
    GothicKidd's Avatar
    Dec 2010
    South Australia
    VY SS
    May 2011
    Auckland
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    u didnt really answer calais cruzin questions? but y do u need a switch? and how long do u sit in ur car 4 and listen 2 ur tunes at a period of time? unless its hours on end i dont see any point if u just turn ur sub off via the head unit.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Quote Originally Posted by wrx884 View Post
    mmm, Well I do listen to my music quite alot... Anywhere from 5 mins to.. 2hours.. depends, I was playing my music in the driveway with the subwoofer and it wouldn't start within 15minutes.
    My batterys becoming a bit old so it doesn't have the life it had before..
    With the H/Unit I dont think it fully turns it off.. There 'power' button is still on at the amp unless u cut the remote wire completely.. I just wanna have some relief without worrying bout if my car is gonna start or not
  15. #15
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by GothicKidd View Post
    new battery and ur switch wont b needed, make sure ur alternator is up 2 scaartch along with its regulator. The amp will just b in stand by mode pretty much so u wont b using any power, really only the light used 2 power the LED in there lol. But if ur gonna sit there 4 a couple hours u should really b starting ur car every so often.
  16. #16
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Dude are you on your phone?
    OP do as suggested with new battery and go from there.
  17. #17
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by wraith View Post
    scratch****** happy? hahaha and no
  18. #18
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Alright no worries, Ive already hooked up the switch and its just so much easier to turn off and on, thanks anyways
  19. #19
    vx s pack II
    Jan 2010
    aLKIDA
    If your battery is old and dies with in 15 mins get a new battery i would get a supercharge battery 600 cca.
    Also load test your alternator.
    There is a thing called amp per hour.
  20. #20
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Dies with the sub going doof doof doof, with it off itll go for a hour or more.. Havnt really tested, Im due for a new battery soon.
    What do you mean 'load test'? :\
  21. #21
    vx s pack II
    Jan 2010
    aLKIDA
    Put the alternator under load. Eg have the car running and put on your headlights,high beams,aircon, rear demister the battery should be reading between 13-14v if its in this bracket i would say its ok you need a multi meter of cause.
    Or you can go to a auto elec and and they will load test the alternator with the propper amp reading and voltage reading under load the best way to do it.
  22. #22
    VY SS
    May 2011
    Auckland
    Does the amp stay on when you turn the car off, If you leave the switch on? I'd say your remote wire is not wired correctly as this shouldn't happen. When the headdecks off the amp should turn off.
    It's not just running the led. The rails will be maintained at a voltage which has inefficiencies and uses power.
  23. #23
    vx s pack II
    Jan 2010
    aLKIDA
    May be its been wired to constant power if it is always on.
    Once had a car come in his complaint was he could only turn on his head unit on via the parker switch Lol.
  24. #24
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Quote Originally Posted by PRAVX II S View Post
    At night with the headlights on and what not, You can hear the alternator whine under Revs.. I dont have a multimeter to test it so..
    m1lky, Yeah it does turn off when I turn the headunit off
  25. #25
    wrx884's Avatar
    Mar 2006
    m1lky, Well Ive got the switch inline with the remote wire so im sure it goes off as soon I turn the headunit off (take keyout)
    Alternator whine means nothing and could b just a bearing so ur best buying urself a multimeter and do wats suggested as it'll come in handy with lots of things.
    u still havent answered milkys question? its like uve just put a band aid over a problem 2 fix it which really u havent.
  1. 92 VP Right hand side Switch Block with headlight switch and DIMMER switch ONLY
    By melmoran86 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2011, 04:13 PM
  2. Post on how to wire up headlight off switch to interior light door switch
    By Bookanun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 12:19 PM
  3. Aftermarket LPG switch linked to Factory LPG Switch??
    By GILLO in forum Electrical Wiring / Questions
    Last Post: 18-01-2010, 03:45 PM
  4. Starter motor/ignition switch/neutral safety switch?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 08:19 PM
  5. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
