Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By blacksv6
Thread: speakers for sv6 ve ute
    2010 ve sv6 ute
    Oct 2010
    syndey
    Default speakers for sv6 ve ute
    just wandering what size my speakers would be and if someone could recommend what sot to buy?
    nothing too fancy just looking for something better then the originals.
    thanks
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    I advise against replacing them. When you say nothing too fancy, i take that as i don't want to spend too much. That's fine and there's nothing wrong with that.
    Some things you should know.
    Just replacing the speakers does not mean it will sound better.
    Replacing the speakers with "better" speakers, does not mean it will sound better.
    What ever speakers you install, will still be sent the same signal. Think crap in, crap out.
    A better set of speakers would also benefit with external amplification. Add an amplifier, plus wiring kit to your budget. If that's too much then scrap the idea completely.
    Speakers + amplifier - bad source of sound. You can use a signal proccesor to improve the sound quality being sent to the speakers. If that's too much then scrap the idea completely.
    You can see where i'm going.
    What is it you don't like about the sound at the moment? If i know in detail what it is that your un-happy with, then possibly i can suggest something. Just replacing the speakers because you un-happy with the "sound" will not get you anywhere.
    HUX 90's Avatar
    HUX 90 is offline POSION VE SS UTE
    09 VE SS UTE
    Mar 2011
    I've put Alpine type R 6.5" splits up the front and a 4" Polk Centre Speaker. the quality is better but It's definately worth amplifing them and if you have the extra cash buying a signal processor as alot of people have told me the stock headunit can damage aftermarket speakers when the volume is above 20.
    As my speakers are not amplified and they have a 4ohm resistance where as the stock speakers have a 2ohm resistance the volume needs to be quite high.
    Pluse if your going for better sound dynamating the doors is definately worth it as mine rattle realy badly when the volume is up high and it sounds aweful.
    Pickle''s Avatar
    Pickle' is offline Donating Member
    VE Omega
    Apr 2009
    Sydney, NSW.
    Sorry, im unsure if i have a signal processor i upgraded my speakers added a sub and amp and the sound is alot better then stock but could deffinately be clearer. How much are these worth and could someone recommend one
    VY Berlina V6 / R31 Skyline
    Dec 2008
    What is your budget? Number 1 would be some new front speakers, a bit of sound deadening and disconnect the centre speaker (if your car has one)
    Amplifier would make a world of difference, though it all depends on your budget. Its better to spend more and do something properly rather than spend a little and try to do too much with a limited budget. But basically, can't give you anymore advice without a budget. You can spend $40 on speakers or you could spend $5k on speakers.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    2010 ve sv6 ute
    Oct 2010
    syndey
    Thanks Guys for your help. I'm prepared to spend a few hundred but no more then ay 400.
    i don't want to be a door door but i want it to sound better then it does now.
    you turn the volume up to 20 and then it just sounds crap.
    I've done a car audio install myself a long time ago but that was in a datsun 120y so I'm a bit scared about my brand new ute and cutting wires here and there.
    thanks
  1. Replies: 5
    Last Post: 09-07-2011, 05:44 AM
  2. [SA] Pioneer - TSA1702C Split System Speakers & Sony XS-F1020 Speakers
    By Tw1n Tur6o in forum Parts And Other Items For Sale
    Last Post: 03-01-2011, 04:50 PM
  3. Replies: 3
    Last Post: 12-10-2010, 04:30 PM
  4. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  5. Replies: 18
    Last Post: 06-01-2008, 07:09 PM
