hey guys, after having a pioneer HU in for a couple of years i now want to get the car looking as standard as possible and get steering wheel controls back again, and im getting older so there is no need for the sub to be pumping flat out! i have the eurovox apart as i am changing the globes to blue led to match rest of dash, not sure how i am going to change the light behind the lcd screen tho?? however i cut the wires on the iso plug too short thinking i would never put the eurovox back in.. can i pull the pins out and re attach wires? also my amp that runs two front splits and 6x9's has a high level input so i will use that but that will use all four speaker wires and i wont have any left to connect another amp for my sub any ideas??
Contact Greg from ASR he can fit u with an AUX input aswell as 2 pairs of RCA's that should sort ur other amp issues.
with the LED in the LCD screen u'll need 2 desolder the LCD screen itself as the globes r under the metal surround in which u can then fit ur LEDs under. Greg can do these aswell.
u should b able 2 pull the pins out they will b a bit of a pain but it can b done easy enoough they just have their own self locking tabs in which u would need 2 release b4 they can come out.
You can pull the pins out i have had to do this before after they have become lose after constantly removing the head unit.
You will need to use a line out convertor to gain signal from one of your speaker wires to convert the signal into low voltage so you can run an rca cable to an amps subwoofer input.
Otherwise as mentioned above just send your factory unit off to "ASR" and it will come back as you want plus with the pre-outs you need.
ok guys so i had a go at pulling the pins out and re connecting the wires, pretty impossible to open up where the wire gets crimped in! tried to solder them in but it was too bulky and solder kept pulling off. SO now im considering keeping the pioneer head unit!!!! my question is, i have three options to run a 4ch amp with the stock HU, 1- use a 4ch line out converter 2- use the speaker level inputs on the amp 3- get greg from asr to install 2 rca outputs. would there be any quality difference between these three as they would all be put through the same amp? is there a way of running my sub as all of the speaker wires would be used without splitting the rear channels? thanks for all your help guys
