Results 1 to 22 of 22
Thread: Sub and Amp questions ( kicker, alpine)
    VT sedan
    Jan 2011
    Lexton
    Question Sub and Amp questions ( kicker, alpine)
    Hey all i bought a sound system installed for $1000 last year all kicker, with amp zx350.4 sub ( comp 150w ) and splits.
    I replaced the comp sub with an alpine type s 300w. At the moment i still have the kicker comp and am going to put it in as well.
    I was just wondering if its worth me getting another kicker ( i like things to be symmetrical ) so that way i have two kicker comps on the side running off the zx350.4 and the alpine running off a 300w monoblock. Or if i should get another alpine type s and run them on the sides and have the kicker comp in the centre.
    Is there a big difference running two 150w subs in comparison to one 300w sub.
    Any suggestions on what i should do?
    Thanks, Darcy
    __________________________________________________ __________________________________________________ _________________________
    Dman's vt exec', 19" vanquish rims, Bagged at the rear , custom boot, 2x 12" subs, tv, xbox360, custom purple interior, dash, seats, door trim, tinted
    http://forums.justcommodores.com.au/...-dmans-vt.html
    Future mods: lowered front, Gto Bodykit, 12mm Plenum spacer, 25mm Manifold insulator, Custom CAI,
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    I wouldn't run 2 different subs in the boot. I the are different power ratings they'll end up competing and it just won't work. That's what I've read anyway. Do I quick searc on running different subs I'm sure the questions has been asked.
    If you run 2 subs it'll just be louder? I dunno about being louder then the type s though.
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    VT sedan
    Jan 2011
    Lexton
    so maybe ditch the kicker and get another type s? i just wanted to use it coz i had it haha and it seemed like a waste not to use it if i could get better sound or louder out of it
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Dont hold me to it but I'm pretty sure it's not good running a less powerful sub with a more powerful one. Just sell it and buy another type s man, then it would be matching anyway.
    My Ride
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    you will get 2 different sounds coming from both subs (it wont sound that good), you are better offer using just the one or get another the same, and sell the other one if you want, what monoblock is that? 300rms? @ what ohm, you might be beter off putting two comps on that or a single type s
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    If they are both the same impedance rating then there is no issue in running both of them. If the amp has seperate gain controls for each channel then you should be able to match the output of the subs fairly well. This is of course unless you are planning on wiring both subs together to change the impedance load, then one might perform better than the other.
    Were not talking SQ competing here or anything, and to be honest in a car the size of a Commodore, and entry level sub, is an entry level sub. All it's going to do is give a small increase in output due to the increase in cone surface area. So i say just go ahead and do it.
    VT sedan
    Jan 2011
    Lexton
    i just had a thought, if i got a 300w monoblock amp that is capable of 2 ohm output would i be able to run the two 300w alpine type s's in parallel at 4ohm? or would this not give me 300w output? i can probably just sell the kicker and run with 2 alpine type s's instead of trying to run with 3 subs, Just thought it would look better :P
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    but then wouldnt both alpine subs be underpowered ? it would probably be better just to run one of them in a really nice box
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Sorry man you taking in rms or peak watts?
    I think they would be underpowered, the type s', if you ran them off the 300watt monoblock.
    My Ride
    VT sedan
    Jan 2011
    Lexton
    yer rms, so what if i bridged the kicker zx350? ( 300w rms when bridged) and then used a monoblock on the other type s? would that sound alright?
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    as long as there both not in the same air space, it would be okay, also you need to set the gains so they sound the same
    VT sedan
    Jan 2011
    Lexton
    yer i have a kicker comp box that come with the setup then i'll make 2 custom boxes with the port holes facing up to the parcel shelf for mega bass, i think i'll get another alpine type s instead of another kicker comp, would be a fair bit better i think.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by DmanVT View Post
    ohh umm have the ports facing to the rear end of the car, sounds better
    VT sedan
    Jan 2011
    Lexton
    what would be louder, facing to the rear or up into the parcel shelf?
  15. #15
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    my friend once told me it would be louder and sound better with it facing the rear, i have my sub up and port facing the rear and it sounds really good. i think it also need at least 1 foot of space from port to the edge for the air
  16. #16
    VT sedan
    Jan 2011
    Lexton
    i see, and does having 2x 300w subs make much of a difference in comparison to 1x 300w sub? ( all same resistance / power )
  17. #17
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Kicker comp is a far better sub then an Alpine. Logic would dictate having 2 subs instead of one would be better.....
  18. #18
    VT sedan
    Jan 2011
    Lexton
    but the kicker is 150W and the alpine is 300w ( rms ) and it hits louder and harder. And yes logic would tell me better, but how much better? increase in feel of bass? increase db? like would it be 3db more or not?
  19. #19
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Well then get the Type S. I was just going off personal experience more then anything. You would feel a bit of extra kick if it was setup properly. FYI I was going off the Kicker CompVR not the plain jane model.
  20. #20
    VT sedan
    Jan 2011
    Lexton
    ahh i see, yer nah i just had the little baby sub haha and yer the alpine's seem to go pretty good also so, i'll see what happens anyway.
    Thanks for the input
  21. #21
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Could also sus out ryda.com for some ideas on subs? Cheap prices.
  22. #22
    VT sedan
    Jan 2011
    Lexton
    thanks for that, will do
  1. [VIC] Kicker 400.1 Amp, Kicker 6x9's + Kicker Wiring Kit!
    By Dinwoodie in forum Parts And Other Items For Sale
    Last Post: 26-10-2009, 05:57 PM
  2. FS - Whole System For Sale! Quality Gear Only, Alpine, Boston, Kicker, Clarion
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 11-06-2006, 03:41 PM
