Results 1 to 11 of 11
Thread: do i need to upgrade wiring with 800 watt rms?
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    Default do i need to upgrade wiring with 800 watt rms?
    hey i have a pioneer 4 way running car speakers 600 watt, and a 100 watt running a kicker sub. i have two power cables coming from battery and bth are 8ga do i need to upgrade the big three? and also will my sub 125rms handle a bigger amp 190watt?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    What are the model numbers of your amplifiers? I can't really understand your first post.
    Also, what are the model numbers of the components you are running from your amplifiers?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    I would go 4 gauge minimum. As said post up some model numbers as the numbers your giving seem to be maximum ratings.
    Sep 2008
    Auburn
    Sorry was kind of in a rush before lunch. I'll post up model numbers of both amps in next hour
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    id do the big three even if you dont need to, the higher voltage the better
    lol forget about that ^ didnt read u were only wanted to run >200rms
    Last edited by Nic92; 18-08-2011 at 04:17 PM. Reason: my bad didnt read the whole thing
    Sep 2008
    Auburn
    Ok so the 4 ch pioneer amp is gm-6400f, the kicker amp running the sub is dx 100.2. The alpine amp which I am wondering if I can run the sub is mrp-t130. Oh and the sub is a 12" kicker 375 watts peak 125 Rms 4 ohm
    Sep 2008
    Auburn
    Sep 2008
    Auburn
    i havent got the boxes for the 6x9's or the splits in front anymore but im pretty sure the fronts were 80w from memory and 6x9's are 160w
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    ur only pushing out about 370rms so the wiring u already have will b suffient as nic said. and the alpine amp will run that sub fine and it never hurts 2 do the big 3 even on a small system like this.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Dec 2008
    The big 3 is wasted on a system like this. The stock wire for the alternator charge wire is ~6awg over a ~60cm run. 85 amp alternator. It will be able to keep up fine with this system. As a rule of thumb, keep your engine earths the same size or larger than your main power cable run, 8awg power cable run, the stock earths are already larger than 8awg. There is no real point, unless you plan on upgrading later, you could do it now. I don't imagine you'd see any real difference.
  1. 2x1200 watt subs , 650 amp , 500 watt amp and 900 watt sub
    By damoscommodore in forum Car Audio
    Last Post: 07-06-2011, 03:46 PM
  2. [WA] 2000 Watt Fusion Amp + 2000 Watt Soundstream t5-15 in box
    By MattyC in forum Parts And Other Items For Sale
    Last Post: 29-03-2010, 12:00 AM
  3. [SA] 2000 watt 2 channel amplifier & wiring kit
    By L67 Calais in forum Parts And Other Items For Sale
    Last Post: 15-11-2009, 10:08 AM
  4. HIDs - 50 watt or 35 watt for low beam
    By Troy711 in forum General
    Last Post: 10-11-2009, 04:57 PM
  5. Watt the
    By VNCommo in forum Car Audio
    Last Post: 01-05-2005, 10:50 PM
