Results 1 to 6 of 6
Thread: Noise filter or ground loop isolator?
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Default Noise filter or ground loop isolator?
    Hey guys,
    I have installed a 4ch amp using the high-inputs and have got really bad noise through my speakers and from my alternator itself. After trying several things like regrounding with a fatter cable in a better spot, moving wiring away from power wire, testing each channel to see if one's picking up the interference, etc, to the point where I took it to an auto-sparky. He said it's the amp causing it as once you take the power wire off the amp, the noise goes away. So he said to install some noise filters and see what happens. After doing a bit of reading and going into a store, the guy told me to use LOC's and ground loop isolators. Will this help my problem? Would I be better off buying the GLI's or noise filters? Or both?
    The only noise filters I can find in stores are only 5amp too which dad thinks will be too low. On the net though I can get up to 40amp ones. I'm thinking of running a 40amp noise filter, and a 4ch ground loop isolator. Will this help or is it all just wasted money?
    A Commodore is a passion. Anything else is just a car
    madnuts's Avatar
    madnuts is offline custom audio installer
    vz 3.6
    Mar 2009
    Penrith
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    madnuts's Avatar
    vz 3.6
    Mar 2009
    Penrith
    are you using a hi-lo rca converter or just from speakers wires to the amp
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    At the moment i'm just running the speaker wire to the high-input of the amp, but planned on running them into a LOC then the ground loop isolator.
    madnuts's Avatar
    vz 3.6
    Mar 2009
    Penrith
    get a hi-lo converter run some rca and see how you go it should rid you of the noise
  1. isolator switch for colored parkers vn
    By rk has a vn in forum General
    Last Post: 31-07-2011, 07:29 PM
  2. Ground loop headache!!
    By BigBoss in forum Car Audio
    Last Post: 29-07-2011, 08:27 PM
  3. 6 Pin Isolator Switch
    By VSEXEC in forum Electrical Wiring / Questions
    Last Post: 07-05-2011, 03:49 PM
  4. VS Ground Loop Noise from iPod
    By justrhysism in forum Electrical Wiring / Questions
    Last Post: 28-01-2010, 01:00 AM
  5. ground loop issue
    By richardpalinkas in forum Car Audio
    Last Post: 16-06-2009, 11:32 PM
