Hi guys atm im running front and rear door speakers anyway this is what i have,
Front doors
Polk Audio - db Series - Mobile / Marie Speakers
Rear doors
anyways i was thinking of straping an amp under the passenger side seat but im not sure what i should be looking for when it comes to amps any ideas would be great
Real cars don't power the front wheels, they lift them
what is your budget ?
you will be looking for a 4 channel amp
cheers mate, these are the 2 im trying to pick from
eBay Australia: Buy new & used fashion, electronics & home d
they look good your should b able to get the kenwood one from a shop for about the same price
Cadence FXA5100 5 channel 1800watt
4x100W + 1x300W @ 4ohms
I prefer extra power and therefore lower on the volume control. It means you can get plenty of volume without pushing the pre-amp hard at all, much cleaner sound. I'd go 4x100, the Polks should have no problem with that.
The Polks are good speakers, but I think you are going to be pretty disappointed by the bass.
Getting a 5 channel leaves you the option of sticking a 10" box in the boot to give you that extra thump later if you want.
i would get a 4 channel then if you want later on go a d class mono block for the sub
Personally I recommend the D Class amps. Small and more efficient than regular A/B amps. I bought a JL XD600/6 to run 4 full range and two subs. Very impressed.
i use to have a 5 channel but blew up ( cheap Jaycar ) i would rather have 2 just incase one blows
They produce a very different sound to a Class A/B amplifier, i'm not sure how to expand a lot more on that. I find class D speaker amps to provide a colder, more clinical sound rather than the warmer dynamic sound of an A/B amp.
Probably off topic however, it's doesn't come into most people's minds haha
Not trying to be rude, but I don't see this as a reason for 2 separate amplifiers over 1 5 channel, no amplifier should 'blow' .. 4/5/mono or otherwise
there is a hifonics zxi60.4+1k which i am getting my friend to buy to run 4 speakers and 2 12's![]()
