Hey guys,
Is there much difference in sound quality with a headeck which has 7 different audio frequncy's v's an Equalizser with the standard Pop/Rock/Jaz/Classic Equalizer options ..
What do you mean by different audio fq's? The pop, rock, ect is just pre-set eq with boosted fq's.
If you want to get more advance with the tuning then it's best done externally.
Fill us in on the rest of the details though so we can better answer your question.
I think the OP is asking about a 7-band panoramic eq vs. preset eq's on a headunit .. If so, then the EQ which allows you to manually adjust frequencies is much better, though if you need a lot of tuning through the EQ I would look at your stereo and fix the issues elsewhere, generally a lot of tuning through the EQ makes things worse.
