Hi guys, just installed a new deck in a mates accord and now the blinkers don't work. Any idea's? Fuse is ok...
95 VS Berlina
http://forums.justcommodores.com.au/...ml#post1891856
I need some statesman/ calais woodgrain for drivers side panel!!
So the hazard lights still work? Check the flasher relay
95 VS Berlina
Flasher relay could be dead. Although it's usually intermittent. I doubt it's anything you've done though.
Try swapping the fuse out even though it looks fine first. Then I'd swap out the flasher relay. They aren't expensive.
not sure if this can help... but when i put a unit in my VS i put a deck mounting screw throght the wiring loom hiding behind a mounting plate. shorted my hand break light in the dash.
if u put mounting equipment through a loom could possibly be an issue lol
yeah ba do a skid ;P
cheers boys ill try everything u've suggested. Thanks for the help.
95 VS Berlina
did you unplug the hazard lights switch?
Thats it! lol, Ijust remembered we did unplug the hazard switch and a few other things to get the radio surround off and I don't remember putting them back in. Ill give him a ring and check it out. Cheers again!
95 VS Berlina
