Results 1 to 5 of 5
Thread: Another Remote wire?
    HSV VXII Clubsport R8 Auto
    Oct 2008
    Perth, WA
    Default Another Remote wire?
    Howdy guys,
    after reading this thread:
    Regards to location of LOC
    Obviously it is better to fit the LOC directly off of the lines that do the rear speakers and tap into them actually physically at the rear of the car, so the RCA leads don't have to travel as far, therefore less interference..
    So I was thinking, it will then be a lot of work to pull apart dash just to install a remote wire if I no longer should be placing the LOC behind the HU... (or did i totally miss understand the above thread??)
    Is there a different location I can attach the remote wire from my stock HU to an aftermarket amp.. or possibly tap into a different output under the dash..? or my rear cigerete lighter as I do not smoke..?
    Any thoughts....
    VE SV6 SERIES 2
    Jun 2011
    Kearns
    I'm eventually doing this in my VE. I was going to run new speaker cable from the head unit to the boot for a loc or straight into a high input amp. You will still need to run a remote wire back to the dash somewhere though. There is some amps on the market that have speaker level input and signal sensing turn on which means you don't need the remote wire. I think any accessories wire is fine.
    The reason I am running new speaker wire means I can go back to the existing stock setup if need be.
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    ur RCA's did they come with a remote wire attacted? most do these days, ive never used them tho always ran seperate wiring incase i got interferance but u could try that and see how it goes? would save pulling up everything again i guess.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Oct 2008
    Perth, WA
    Quote Originally Posted by wrx884 View Post
    Hey mate, I am yet to buy anything... have a look at this thread for me here
    Maybe you will be able to answer a few of my questions.. and with an LOC it has a wire for the Left pos an neg and right pos and neg and a ground? or am i missing a wire...? (visualizing in my head, I am at work atm..)
    How exectly do i hook it up if i wanna hook it up directly at the rear
  1. Remote wire
    By Dan_VX_Spac in forum Car Audio
    Last Post: 10-07-2009, 11:54 AM
  2. VY remote on wire for amp
    By c0mmodore in forum Car Audio
    Last Post: 05-02-2008, 08:10 PM
  3. can i run a remote wire of another remote wire
    By Burnout_bro in forum Car Audio
    Last Post: 07-05-2007, 11:16 AM
  4. Remote wire
    By [NatHAn] in forum Car Audio
    Last Post: 15-04-2007, 02:46 PM
  5. Amp remote wire
    By yogi_6_9 in forum Car Audio
    Last Post: 19-01-2006, 01:41 AM
