Results 1 to 8 of 8
Thread: Any one used "THE CAT"?
    '94 Holden Calais VR V8
    Jan 2009
    Western Suburbs, Melb
    Default Any one used "THE CAT"?
    Came across this and its something I really wouldnt mind having in my car! Just wondering if anyone has used this before and wondering their thoughts on the product? Pro's & Con's? etc..
    THE CAT
    VY S/II S Pack
    Apr 2011
    Yeah, people have used them and work brilliantly. The PAC SWI is also highly recommended. Aerpro also have an offering too, available from a few buyers on eBay.
    Jonno's Avatar
    Jonno is offline :)
    Vk
    Nov 2010
    Vic,
    Do you have a vehicle with steering wheel buttons and want to upgrade your headunit with a "high performance" system and realised the steering wheel buttons won't work?
    If so you'll need THE CAT. It's a car audio steering wheel interface that allows you to replace the standard audio system, whilst retaining the steering wheel audio functions.
    HOW DOES THE CAT WORK?
    1. THE CAT recieves a signal when a button is pressed from the
    steering wheel.
    2. THE CAT then converts the signal to be understood by the headunit.
    3. THE CAT then sends the signal either via infrared or direct connect
    to the headunit.
    No programming involved - frequencies are already programmed in therefore no delay between button presses.
    so itll make the steering controls work with a aftermarket head unit.. souunds like a good idea
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    Jan 2009
    Mk2
    Mk2 is offline
    VX Calais S2
    Oct 2010
    Are this thing and the one by Aerpro both straight plug and play? I have my headunit wired up with an Aerpro harness so how do the steering control harnesses connect up in that scenario?
    vy commodore executive S2
    Jan 2011
    From my experience,cat systems are way too expensive and they use infrared qnd if any thing comes in its way while u pressing the command frm ur steering wheel , it would not work, where as pac-swi systems works totally differently and are for like $90 and also support bluetooth handsfree comands. Me and my mate both got pac systems for last 6 mnths and theywork fine, even after u unplug car battery.
    U have to select which 1 u after as there r diff system for different head unit brands
    Jan 2009
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by Mohi View Post
    the CAT uses wired and infrared, but from memory it doesnt like vr/s with some wired units. would have to read the instructions
    Quote Originally Posted by ZU00KI View Post
    Okay, so what do people recommend and what other brands are their?
    ive used the aerpro ones on a few cars, for the most part theyre pretty good, but still in the teething stages. pac swi is good, not sure if itll work with vr though, again, read the instructions, see if it supports it.
    be aware that most of them will be limited to mostly the big name headunit manufacturers.
  1. Do "police pack" cars have a standard v6 or the "high output" one?
    By Gibson_83 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-08-2011, 05:42 AM
  2. [LS1] Power "Lag", "Sluggish", "Doesn't feel right"
    By TA 91 WA in forum LSx Development and Modification
    Last Post: 04-12-2010, 07:38 PM
  3. WM Statesman - "Contact Dealer" and "X Service" and Empty fuel gauge issues
    By selimlok in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-11-2010, 07:15 AM
  4. Replies: 13
    Last Post: 26-03-2009, 05:34 PM
  5. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 06:59 PM
