Results 1 to 3 of 3
Thread: Tips on fitting 6.5" speakers to 6" pod
    VS Berlina
    Aug 2005
    Default Tips on fitting 6.5" speakers to 6" pod
    Hey all,
    Just wondering if anyone has had experienced fitting 6.5" front splits (any brand, but the jaycar precision kevlars are the exact product) into their VS door pods and how they went about it, or if there was a reputable car audio store that fitted them for you to your satisfaction (in melbourne)?
    Any help appreciated,
    Cheers, Killer
    V6 VS EXEC S2
    Sep 2005
    i am just fitting some 6.5" to my VS, and am in the process of modifying the pods. what you need to do is cut the pod down where it protrudes from the speaker mounting surface. i used a hacksaw, there are other ways to do it. i then removed the basket cover from the middle, you may or may not need to do this. i used a hacksaw blade for this too. make sure you cut the re-inforcements attached to the basket cover with tin snips (or similar) to the same sort of angle as the other angled re-inforcements. clear off any burrs and crap from the pod. i came across this great product called plasti-bond (from selleys) which i used to fill in all the gaps, it is super strong, and easy to sand, drill, tap into etc. then, with a belt or orbital sander sand the face of the pod down flush. clean up the inside diameter of the hole with sandpaper. i needed no further spacers to fit the magnet inside the door. then, simply screw on your speaker and seal with silastic or similar to ensure an airtight bond. i can email photos or answer questions if you like.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    my 6.5 inch pioneer TSC-106R's fit in, just, after i cut one hole in the outerring with a file, where the bits stick out on the speaker. If that makes any sense
  1. installing 6"X9" speakers on vs parcell shelf?
    By debono55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2012, 11:09 PM
  2. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 05:59 PM
  3. Replacement Speakers front doors VX Commodore 2001. 5.25", 6" or 6.5"
    By antis0cial in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2007, 03:03 PM
  4. fitting 6" speakers to the door, what do you think??
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2005, 12:03 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
