Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By sweefu
  • 1 Post By sweefu
Thread: Stereo making wired noise???
    VZ SS
    Jan 2011
    Default Stereo making wired noise???
    I got in the car today mid arvo and it had a sound coming from the speakers that sounds like when your on radio and there is no signal but very quite then when the car revs up there is a whistle but if the i hit the brakes the whistle stops for for a second them comes back. It all goes away when the head unit and power to all amps is turned off by the button on the head unit. It was raining today so i dont no if water could have got into anything. Could i please get some help with this???
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Is the power wire run next to the RCA wires? Is(are) the earth(s) sanded back to bare metal?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by sweefu View Post
    As above, interference from power wires and RCA cables run together or a bad earth as a result of poor preparation or placement.
    Solution/s (depending on which installation issue it is you're facing):
    Run RCA cables down the opposite of the car to the power cables.
    Re-do the ground on a piece of metal that has been well sanded back (to get rid of resistance due to paint).
    VZ SS
    Jan 2011
    Sorry to sound stupid but what are RCA cables and i got the install done at a shop where would the earth be? The stereo has been in for about 6 months y would something start now?
    Dec 2008
    If the install was done at a shop, it *should* all be ok .. Which shop? If you've paid a professional to install the stereo, I would take it back to them.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Take it back to the shop then. We can't help if you don't know what an RCA is.
    [edit]
    Too slow, beaten by 2 minutes
    Dec 2008
    Haha! Uni has honed my typing skills.
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    haha mine sounded the same when i first tested the amp and then i tested it with my laptop and it was really clear i was thinking it was the cheapy china head unit but i had wires all over the place. i cant connect it properly untill i get my wood
    Dec 2008
    Quote Originally Posted by Nic92 View Post
    Of what relevance is this?
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    VY S/II S Pack
    Apr 2011
    Glad you realise that Nic, perhaps you should ask yourself that before you post that next time?
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by Harris View Post
    Google
    My advice is that you don't go playing around with anything. If you go playing around with things, especially with the battery connected and so forth, you may wind up with much more than some interference noise.
    As above, take it to a shop, or where yo had the install done.
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    VZ SS
    Jan 2011
  15. #15
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  16. #16
    VZ SS
    Jan 2011
    Got subs put in on the weekend so i got the noise looked at and they said it is a bad connection in the amp so it needs to be sent away. (Not happy)
  17. #17
    Mar 2009
    Cairns White Rock
    Seems a bit odd that the power stage of the amp was still working but that they want to send it away. Where is the bad connection? I'd have a thought they be able to fix what ever the connection issue is. Unless the amp is under warranty and doing anything to it would void it.
    Where do they have to send it off to? It might pay to find out the list of service agents, sometimes there's one nearby by.
  18. #18
    VZ SS
    Jan 2011
    They said the RCA cable into the amp for the speakers has a bad connection. The people sound stream tell you to send it to is in Perth so that's good for me. also i hit a bump in the road the other day and all the deck lights went off so there has to be a bad connection somewhere.
  1. VR V6 making a bad rattling noise :(
    By dk4400 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2011, 08:48 AM
  2. Vn v6 making bad noise :|
    By Rhys954 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2011, 05:02 AM
  3. My ute is making a noise
    By Tullyban in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2010, 12:48 AM
  4. indercater making noise
    By manual VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2006, 10:19 PM
  5. vs ute making strange noise
    By MATT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2004, 07:11 PM
