Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Like Tree4Likes
Thread: Amp for JL Audio W3 D4 Twin 12"s?
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Default Amp for JL Audio W3 D4 Twin 12"s?
    Hey everyone... Just wondering if anyone can recommend an amp or sell me one even for 2x JL Audio W3 D4s with the following specs.
    Nominal Impendance: Dual 4Ω Power Handling (continuous): 300W
    Cheers.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Something that makes 600Wrms or more into 1 channel at 4 or 1 ohm. Can't recommend brands.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by StoneX View Post
    Hmm ok, thought I might need more like 800-1000WRMS.
    What's the difference between 4 & 1 ohms?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Ohms is the unit used when measuring resistance. You could have an amplifier that produces anywhere from 600wrms + to infinity. Just be sure to set the gains correctly on the amplifier when tuning. What sort of budget are you looking at?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by sweefu View Post
    $100-$350 ideally. I don't see the point spending much more than that.
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    i know hifonics amps do alright, pm me if you interested, there il shh now coz these other ppl on this forum are so negative against them
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by Nic92 View Post
    I hope it's not as awesome as the Eonon head units you liked too
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    haha no way Eonon are the best LOL. hehe but seriously the amps are pretty good for there price
    VY S/II S Pack
    Apr 2011
    Don't listen to Nic haha :\
    Option Audio equipment is highly recommended around here as excellent value gear. You have two options.
    The first option is their 600W RMS monoblock (which produces 600W RMS at 1 ohm): From here for $249
    The 600W amp is perfect for your subwoofers and is able to power both with 300W RMS when run together in parallel to produce a 1ohm load, however it leaves no headroom if you wish to upgrade to more power-hungry subwoofers at a later date.
    The second option is their 1200W RMS monoblock (which produces 1200W RMS at 1 ohm): From here for $339
    The 1200W amp is more than capable of powering your subwoofer, and allows a lot of headroom if you wish to upgrade your subs at a later date. For only $90, the investment is worth it.
    To ensure your amps don't over-power your subwoofers, you will need to turn down the gains and ensure that you don't hear the subwoofers struggling at a higher volume.
    If you need advice on how to set your gains or how to wire up the subwoofers in parallel to produce a 1 ohm load, just ask.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Dec 2008
    Wire them like this for a 1ohm load mate!
    http://a248.e.akamai.net/pix.crutchf...no-low-imp.jpg
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    VY S/II S Pack
    Apr 2011
    Yes, if the subs are the JL Audio W3 D4, then it has two 4 ohm voice coils (hence the D4). This means that each subwoofer has two inputs for the voice coils and can be wired into 2 ohms by following that diagram of Sweefu's, and then wire them together to produce 1 ohms, as in Sweefu's diagram.
    Follow the diagram and you'll be fine.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by MAG00 View Post
    Oh I see
    Cheers guys, see how we go.
  15. #15
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Where's the best place to buy cheap wiring kits? I was looking at the kicker kits, they look great and quality but are just so ridiculously overpriced. I'd be spending more than I spent on my head unit just on wiring!
  16. #16
    VY S/II S Pack
    Apr 2011
  17. #17
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Aerpro kits from Autobarn or JB are fine.
    But you can usually get them thrown in free or really cheap from the store you buy the other stereo gear.
  18. #18
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    All depends on the size you want. This kit here is quite good for the price.
    4AWG, with a distro block. and need 3 sets of RCA's and a bucket load of speaker wire.
    That linked one actually looks good! cheers!
  19. #19
    VY S/II S Pack
    Apr 2011
    Do you have more than one amp?
    If not, you won't need 3 sets of RCAs or a distro block (you will need the fuse + holder, if you're confusing that with a distro block)
  20. #20
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    lol hahahahah.
    Yes 4ch & Mono.
  21. #21
    Dec 2008
    +1 For Aerpro power wire kits, very good quality wire for the money. I've always bought Aerpro power wire.
  22. #22
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Cheers man, good to know. When I did the install in my VS I used a cadence kit... the RCA's were terrible, they broke off at the ends, there wasn't enough speaker wire, etc, etc. and it wasn't cheap either.
    Aeropro kit looks like the go, kicker's kits look heaps better but not worth the money.
  23. #23
    Dec 2008
    The Aerpro standard RCA's are pretty poor quality imo, go for the Aerpro crystal or better yet Stinger Pro series RCA's, Level3 are usually $25 / 6 metre run.
  24. #24
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
  25. #25
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by Trayner View Post
    I got my 0 gauge kit from American ebay , cost me $50 , so I reckon you could get a good 4 gauge for like $30
    What about postage? Wiring kits are heavy and heavy items have significantly higher postage.
  1. [VIC] VT-VY Twin 2.5" Catback,VR/S Adjustable Sway Bar, SL Springs, Pioneer 12" Sub + More!
    By shaune_m in forum Parts And Other Items For Sale
    Last Post: 17-11-2011, 10:15 AM
  2. Manta Twin 2.25" catback into single 3"?
    By slmnvz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2011, 12:09 PM
  3. WTB: VN-VS live axle exhaust 3" or twin 2 1/4"
    By na3point8 in forum Swap / Wanted to Buy / Trade
    Last Post: 14-09-2008, 06:59 PM
  4. SA:FS/SWAP Twin 12" Us Audio Subs
    By Kyle23 in forum Parts And Other Items For Sale
    Last Post: 07-08-2008, 09:35 PM
  5. SA EOI Twin 12" Us Audio subwoofers
    Last Post: 08-07-2008, 04:25 PM
