Results 1 to 12 of 12
Thread: Actual subwoofer rattling
    writeoff's Avatar
    writeoff is offline 0 to 100... eventually
    VS Wagon
    Jul 2011
    Default Actual subwoofer rattling
    My subwoofer has started to make a rattle noise internally I believe, it almost sounds like air escaping, the box it still fully sealed but when it kicks it makes that noise. Does any one have some insight as to what is causing this? I don't really know a whole lot. It is only two months old.
    Be patient, I am inquisitive and I am learning.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Well what sub is it,
    what type of enclosure is it,
    who built the enclosure,
    what amp do you have,
    have it always done it, or is it only something recent,
    does it do it at all volume levels,
    writeoff's Avatar
    VS Wagon
    Jul 2011
    It is an alpine s type 12" I think
    Sealed
    Built by my dad to exact recommended specs
    The amp is an alpine MRX-M50
    No, only started roughly mid last week
    Yes but at low volume it is difficult to hear the noise, as the volume increases it gets louder but not at the same scale, it increases faster (ie if the volume is linear and the noise is exponential)
    VY S/II S Pack
    Apr 2011
    Take the subwoofer out of the box and inspect it. Closely observe for any loose or broken parts.
    writeoff's Avatar
    VS Wagon
    Jul 2011
    I did that this arvo, unfortunately I can't see any of that, not even signs of heat, looks identical to the day I bought it
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    re seal the sub box even if it looks ok and see if that does anything.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by writeoff View Post
    Play music through the subwoofer while it is outside of the box. You won't damage it. Just keep the volume down, it will be very noticeable if you're pushing it too hard.
    VY SS
    Feb 2008
    sunny coast
    There was no funny smell to the sub either? Voice coil might be a long shot, you'd probably have known as soon as you pulled it out would have smelt bad but its a possibility if the sub is making a weird noise and not generating a deep tone.
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by wrx884 View Post
    Just a side note if your planning on using silicone let it completely cure before putting the sub back in the enclosure.
    writeoff's Avatar
    VS Wagon
    Jul 2011
    Quote Originally Posted by patrick niesler View Post
    Nope, smelled perfectly fine.
    @HCVP I will let it set before testing, thanks for the head up. Hadn't planned in silicone but may as well.
    Monaro CV8R, Landcruiser 100 Series 4.7L
    Jun 2011
    Once you have checked the box and re sealed it if it still happens it may be the voice coil is stuffed. They can scrape along the inside of the magnet.
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by Crisis63 View Post
    It could be a number of things, from cone surround coming loose to voice coil rub. Which is exactly why I suggested he runs the subwoofer out of the box, so he can identify where on the subwoofer the noise is coming from.
    Take the subwoofer out of the box, run it at a low volume and listen for issues.
  1. Actual news headlines
    By VTLS1 in forum Jokes/Humour
    Last Post: 30-08-2011, 01:50 AM
  2. [WA] slim subwoofer/amp or subwoofer tube for my VU SS ute
    By alshemary in forum Swap / Wanted to Buy / Trade
    Last Post: 18-06-2011, 03:44 PM
  3. ACTUAL VE Pre Launch Spy Shots - Library
    By SSV8pilot in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-05-2006, 07:53 PM
  4. alpine V12 amp actual wattage
    By semi in forum Car Audio
    Last Post: 08-10-2005, 01:20 AM
